Old 05-24-2005, 01:33 AM   #1
67ChevyC10Stepside
67ChevyC10Stepside's Avatar
how hard to go back to 6 lug?
what all would be required to change my truck back to 6 lug? i want to run 4x4 rallies on it and the guy before me changed it to 5 lug and i dont really like the 2wd rallies....
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon)
WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt.
67ChevyC10Stepside is offline   Reply With Quote
Old 05-24-2005, 06:40 AM   #2
NPilot1975
NPilot1975's Avatar
Hart_Rob has all the peices you would need for the frontend and then all you would need is a six-lug rearend.
1972 Blazer body...need to get a thread started for the rest of the story
NPilot1975 is offline   Reply With Quote
Old 05-24-2005, 07:30 AM   #3
Burnsman
Chevy Freak
Burnsman's Avatar
6 lug stuff
I have all the 6 lug stuff (rear and front setup). I'd trade if you wanted.
69 GMC SWB, 350
70 Chevy LWB, 350
55 chevy gasser, 461
73 Camaro, 496
67 RS Camaro, 406
64 Chevelle, 588
71 Nova, 565
67 Camaro, 461
Burnsman is offline   Reply With Quote
Old 05-24-2005, 09:30 AM   #4
Joe67
67 is sold
Same here
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 05-24-2005, 10:33 AM   #5
arkracing
Weekend Warrior
I'd trade a 6-lug rear for the 5-lug rear (but you are kinda far away)
if your truck already has a 5-lug front end..you can buy aftermarket 6-lug rotors from the board vendors or Early Classis or CPP
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 05-24-2005, 11:19 AM   #6
stelth2002
Young Gun wth Fast Inline
stelth2002's Avatar
I have what you need as far as the read. Some 6 bolt axles and some drums. You would just have to put the axles in and the drums on. Willing to sell outright for cheap.
JT
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!!
stelth2002 is offline   Reply With Quote
Old 05-24-2005, 11:41 AM   #7
71HUGGER396
Confirmed Truckaholic
71HUGGER396's Avatar
Do you want front drums, or disc brakes?
1968 50th STEP SIDE SHORTY, 350/350, a/c, ps, p,b
Daily Driver, 1970 Cst short fleet, all black, 350/350,
1970 2wd Blazer, 2wd, 6 cyl. 3 spd, original, now a 454, 350turbo, 3.73 posi, on the road
1971 2wd fleet shorty, 454, 700r4, 3.73 posi, SOLD to 67OLDSTYLE72
"My rig's a little old but that don't mean she's slow" - SAWYER BROWN's Six Days On The Road
SEMPER FI "I use to be a lean mean fighting machine, but now I'm a huffin, puffin, over stuffin love muffin"
71HUGGER396 is offline   Reply With Quote
Old 05-24-2005, 02:48 PM   #8
67ChevyC10Stepside
i would prefer the newer 6 lug discs....cant i take my rearend and pull the 5 lugger axles and replace them with 6 luggers? what all has to be replaced is my question..not just...i have everything..
Old 05-24-2005, 03:39 PM   #9
68speedalert
Semi-Senior Member
68speedalert's Avatar
As far as I know, you can't just change axles. The 5 lug diffs are wider. Now it's possible that a later model 4x4 may have the same shaft as you are needing.
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre
'83 Jeep CJ-7, <80,000 miles, original owner
'04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer
'95 GMC K1500 Extended cab
68speedalert is offline   Reply With Quote
Old 05-24-2005, 04:56 PM   #10
71HUGGER396
What is your front end now, drums or discs?
Old 05-24-2005, 05:05 PM   #11
krue
Designated A-hole!
krue's Avatar
Actually a rearend from the last half of the 70 model year is the same width as the 71 and up rear ends.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 05-24-2005, 05:10 PM   #12
67ChevyC10Stepside
mine is 5 bolt front and rear with coils and disc front drum rear...
Old 05-24-2005, 07:08 PM   #13
71HUGGER396
To change your front, you would have to buy special 6 lug rotors from someone like GMCPaul's. But you won't have to change anything else on the front end. I think they're $85.00 a side.
Old 05-25-2005, 07:12 AM   #14
MOTHERTRUCKERS
Cheapest way to go is redrilling your rotors, axles and drums if they are in good shape. Our local machine shop charges 25.00 for each rotor or axle plugged,drilled with new studs installed.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 05-25-2005, 07:26 AM   #15
Bowtie67
Bowtie67's Avatar
I have a set of 6 lug axles also have a complete front suspension with drums and lowering springs for both front and rear. I also have a set of the blazer rims with tires, But as to note a little like Krue stated about axle lengths, if they switched out the whole rear and put in the later rear end in your truck you will have to switch it out for the earlier rear end, I believe it was 70 & up the 5 lug setups where wider and needed longer axles. Some have adapted the longer axles to work in the earlier diffs by making some sort of spacer in the axle bearing area.
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears
1948 Chevy FleetMaster Coupe, LS1, (almost done)
1950 Chevy StyleLine Coupe 250/6 3x2 Dueces
2009 Toyota Tundra
1996 Harley RoadKing
"I maybe getting old, but I can still burn rubber with the best of them"
Bowtie67 is offline   Reply With Quote
Old 05-25-2005, 10:15 AM   #16
68speedalert
Semi-Senior Member
Thanks for the reminder...I had forgotten about those.
Bowtie67, that should read "71 & up....."
70's had 6 lug.
Old 05-25-2005, 01:58 PM   #17
67ChevyC10Stepside
shoot...seems like a lot of bull ****e i dont really wanna try to figure out...
