Old 06-03-2005, 05:24 PM   #1
backinblack
Lowering question
I just went and got some new tires today. I went from running 235/60/15 on an 8 inch rim in front, and 275/60/15 on 10 inch in the rear to 275/60/15s all the way around.
My problem: Truck was nice and level before, but now because of tire change, the front is approx. 1 inch higher than rear. I love how the bigger tires fill out the huge wheel/fender well in front, but I need to bring the front down 1-1 1/2 inches to make me happy. What's the easiest way to do this besides torching....... I don't have the means for drop spindles, and don't need a full 2 inches.......Any advice appreciated.
TIA
69 chevy SWB
70 GTO
65 GTO hardtop
65 GTO ragtop
77 Trans Am
Hmmm. Too many pontiacs, not enough chevy trucks yet.
backinblack is offline   Reply With Quote
Old 06-03-2005, 07:21 PM   #2
farside847
farside847's Avatar
1" drop springs?
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 06-03-2005, 07:25 PM   #3
5150
C10 Club Tennessee
5150's Avatar
You can try cutting a half of a coil off the bottom of the front springs. I think that would be 1 inch drop and it's the cheapest.
Correct me if I'm wrong guys, but that should do it.
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 06-03-2005, 07:57 PM   #4
matthufham
a big block might lower it. i took the sb engine out of my truck and the front lifted 3 inches. it looks like a pre-runner now with the high front end.
matthufham is offline   Reply With Quote
Old 06-03-2005, 09:48 PM   #5
shortbed70
shortbed70's Avatar
Its alot of work but start with a quarter coil cut and set down on ground and remember it will settle in some. Don't go to far.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 06-03-2005, 09:59 PM   #6
pissonNOS
senior member
pissonNOS's Avatar
i cut 2 coils out of my truck and it dropped it 3 inches if that helps any I would cut a ful coil out of yours
P.S. I used 3/4 ton springs if that matters
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 06-03-2005, 10:03 PM   #7
71HUGGER396
Confirmed Truckaholic
71HUGGER396's Avatar
I would go the 1" drop springs also.
1968 50th STEP SIDE SHORTY, 350/350, a/c, ps, p,b
Daily Driver, 1970 Cst short fleet, all black, 350/350,
1970 2wd Blazer, 2wd, 6 cyl. 3 spd, original, now a 454, 350turbo, 3.73 posi, on the road
1971 2wd fleet shorty, 454, 700r4, 3.73 posi, SOLD to 67OLDSTYLE72
"My rig's a little old but that don't mean she's slow" - SAWYER BROWN's Six Days On The Road
SEMPER FI "I use to be a lean mean fighting machine, but now I'm a huffin, puffin, over stuffin love muffin"
71HUGGER396 is offline   Reply With Quote
Old 06-03-2005, 10:24 PM   #8
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
I would cut first because your not considering the age factor. What if the 1" drop springs make it higher ?? Springs sag over time, Cutting is cheaper.
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 06-03-2005, 10:33 PM   #9
djracer
djracer's Avatar
if you do decide to cut I'd only go in half a coil increments I'd also put the coil in a bucket and fill with water up to were I was going to cut it! That keeps the coil from getting hot and losing temper!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 06-04-2005, 12:00 AM   #10
Green Machine
Green Machine's Avatar
I'm not a spring expert by any means, but don't the top and bottom ends register in a slot/groove on each end ? Wouldn't cutting 1/2 coil instead of 1 coil cause the spring to be mis-indexed in it's fitting ? I may want to do this someday myself.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 06-04-2005, 05:22 AM   #11
lngbed71
Nothing fits but the oil
lngbed71's Avatar
Naw...no worries about slot/grooving alignment. Zap off half a coil, that will give you about an inch drop. Don't go too much or you may wind up with wheel alignment/toe/camber problems.
Land of the free
Because of the brave
lngbed71 is offline   Reply With Quote
Old 06-04-2005, 11:13 PM   #12
Low69CST
I would start with cutting 1/4 of a coil. I did that to mine and it made a big difference.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 06-05-2005, 06:47 PM   #13
backinblack
I think I'm going to cut the coil then........Can anyone tell me the easiest way to remove the coil spring without killing myself..........
Thank you!!
69 chevy SWB
70 GTO
65 GTO hardtop
65 GTO ragtop
77 Trans Am
Old 06-05-2005, 08:11 PM   #14
70short/step
70short/step's Avatar
If you did go with the 1" lowered springs just remember that your original springs are old and have sagged some. So a 1" dropped spring may not make a difference.
For every person with a spark of genius, There are a hundred with ignition trouble.
70 Short/Step
70short/step is offline   Reply With Quote
