Old 06-18-2005, 02:06 PM   #1
88Jimmy4x4
88Jimmy4x4's Avatar
AC only blows on HI.........wtf?
My AC in my burb will only blow on HI fan speed, anything other setting is like its turned off. It was working fine and just started this.
Is it the controls? relay? I dunno wtf
Anyone know whats wrong?
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 06-18-2005, 02:19 PM   #2
Earl Filter
Earl Filter's Avatar
Blower motor resistors - common, easy to replace and cheap. There's about a 98% chance that's what it is. They're what gives you any fan speeds other than high.
EDIT: A quick check at rockauto.com says you'll be out between $9 and $11 for it. I don't know these trucks all that well, but the resistor pack is either going to be on or near the passenger side firewall, or under the passenger side dash. It's going to be near the blower somewhere! I just saw you're in Sealy...I'm only 1/2 hour away! Any parts store should carry it, by the way.
Real Name - Brandon
Current Vehicles:
1977 C20 Silverado 454/TH400 3.73s
1989 Jaguar XJ6 in the middle of an LT1/4L60E swap
Earl Filter is offline   Reply With Quote
Old 06-18-2005, 03:11 PM   #3
BALDMIKE
Enormous Member
BALDMIKE's Avatar
Well you're lucky, mine only blows on low and medium, high is out.
I was told it was a fan relay ?
Anyone have a link or part # ?
"79" Chevy Stepside 350/350
Check my Blog @ www.BaldMikesWorld.blogspot.com
BALDMIKE is offline   Reply With Quote
Old 06-18-2005, 07:43 PM   #4
88Jimmy4x4
88Jimmy4x4's Avatar
Thanks Earl, located the part on the condensor shroud under the hood.
I hope o-reilly carries it.
1991 GMC Jimmy 4x4
Old 06-18-2005, 08:38 PM   #5
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Replace the fan relay. I had the same problem. I paid like $5 for the relay.
Old 06-18-2005, 09:38 PM   #6
88Jimmy4x4
88Jimmy4x4's Avatar
Okay well both parts are on the condensor housing shroud, now which one do I try first?
1991 GMC Jimmy 4x4
Old 06-18-2005, 10:16 PM   #7
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Check the wiring. The high position uses a separate wire. It has a connector in it, and they sometimes burn up. I had it happen on my old Cutlass, and have seen several people report it happening on their truck.
The connector on my Cutlass ran across the top of the engine, and the connector was near the carb. I can't remember if it is there on the truck or somewhere else.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 06-19-2005, 12:02 AM   #8
Earl Filter
Mine. Trust me.
Real Name - Brandon
Current Vehicles:
Old 06-19-2005, 12:23 AM   #9
1FaastC10
1FaastC10's Avatar
there is no such thing as a condenser shroud, the condensor is mounted in front of the radiator.
1FaastC10 is offline   Reply With Quote
Old 06-19-2005, 01:13 AM   #10
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
Yep, it's the evaporator case.
With it working on high, the relay works. Not working on the other speeds is the resistor, interconnecting wiring, or a switch failure on your controller just like others have said. I'd go with the resistor first.
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '87 C10, '87 R30, 2 '89 R3500 Flatbeds
ElGracho is offline   Reply With Quote
Old 06-19-2005, 10:01 AM   #11
88Jimmy4x4
88Jimmy4x4's Avatar
Okay well I removed the resistor, but looking at it everything seems fine. If its bad would one of the springs or something be broken or loose?
1991 GMC Jimmy 4x4
Old 06-19-2005, 10:05 AM   #12
88Jimmy4x4
88Jimmy4x4's Avatar
oh and theres actually 2 different resistors locations, one goes to the blower motor and looks like this:http://198.208.187.182/servlet/com.e...partnbr=336403
the other one is located on the opposite side and just has a connector and the wires go into the firewall and looks like this:http://www.smpcorp.com/web_app/catalog/images/RU64.jpg
I assume its the first one since it joins the wire harness that goes to the blower motor, is this correct?
1991 GMC Jimmy 4x4
Old 06-19-2005, 10:06 AM   #13
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
Yes, they would look burnt. Time to check the switch or wiring to the fuse box (assuming you already checked the fuse).
Usually when the resistor block blows, only one of the resistors goes bad, therefore you will loose low and one of the intermediate speeds. Not saying that both cannot be blown at the same time, but assuming all speeds worked since you have had the truck you are more likely to notice two of the speeds stopped working before the resistor block goes totally bad.
Looks like you were typing while I was. Wouldn't hurt to check both, but the one which connects to the blower motor is the one.
NeCrOmAnCeR is offline   Reply With Quote
Old 06-19-2005, 04:52 PM   #14
88Jimmy4x4
88Jimmy4x4's Avatar
well o-reillys doesnt carry the blower motor resistor part and rockauto.com wants $8.93 for the part and $8.75 for shipping so its still not fixed, guess I will check parts stores in Houston while Im at work tomorrow.
Side note: I can unplug the connector from the resistor and the system works the same only on HI FAN speed.
If it were a fuse, I would assume it wouldnt work at all right (not even on HI)?
1991 GMC Jimmy 4x4
Old 06-20-2005, 01:01 AM   #15
jimfulco
Sometimes you have to get the switch lever in EXACTLY the right position before it will pass juice. Also, wiggle all your electrical connectors & see if it's just some corrosion on the contacts that's causing the problem.
jimfulco is offline   Reply With Quote
Old 06-20-2005, 01:51 AM   #16
gchemist
gchemist's Avatar
Take a voltmeter and check the relay!!! IT'S THE RELAY!!!
Old 06-20-2005, 10:58 AM   #17
88Jimmy4x4
88Jimmy4x4's Avatar
Its kinda weird, when you first turn it on it blows cold on HI, if you lower the lever one notch it will blow, then cutoff...then blow...then cutoff for good till you move the lever to hi then it blows fine...kinda weird like something heats up then doesnt work.
1991 GMC Jimmy 4x4
Old 06-20-2005, 04:52 PM   #18
88Jimmy4x4
88Jimmy4x4's Avatar
does anyone have the electrical schem for the ac system online?
1991 GMC Jimmy 4x4
Old 06-21-2005, 10:06 PM   #19
88Jimmy4x4
88Jimmy4x4's Avatar
I removed the resistor, looked good, measured ohms good, and was getting voltage so I knew that wasnt it.
Next....the relay....yup that was it, problem fixed...gchemist was right
1991 GMC Jimmy 4x4
