No No
Changed my U-joints toady, dident bother to mark the shaft as far as I know it doesent need to be clocked in any certain posistion. I ask because there is a slight bit of vibration now that wasent noticeable even with the two screwed up U-joints.
Edit: This is the 100000000 time its been out so I couldent have been lucky every time but now right? BTW U-Joints went in nice no binding whatsoever.
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler Last edited by SSC's76; 06-16-2005 at 07:57 PM. |
STILL PLAYS WITH TRUX
You should always do it if you can cuz the shaft has small balance weights spot welded to it and its balanced in that position.
But since you r&r the u joints and there not exactlly mfg. to close tollerances as far as weight go's so it may not matter anyways if you did clock it . You may have to take it to a drive line shop for ballancing. |
u joints shouldnt make that much of a difference in the weight. my guess would be that your rear joint is favoring one side of the yoke more than the other. while it wont bind like that, it will definitely give you a vibration. get it checked out ASAP, because an imbalanced driveshaft will eat your pinion bearings in a very short time.
No No
I re-checked it an hour ago, everything is set in correctly swaped the yoke around, dident make any difference. Checked for excessive heat too since that would be an indicator or side load or a faulty/damaged roller bearing, nothing found. I've actually been debating to spend the $80 to have the DS ballanced but Ive been holding off in hopes of finding an aluminum replacment.
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
#5 | |
driving is in my blood
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
What you say sounds good!
But the factory GM maintenance manual tells you to mark/clock the position of it when it is removed so it can be put back in the original positoin. It probably wouldn't matter any ways as old of a truck that he has who knows how many times its been removed and replaced. Im lucky i bought my truck new and i clocked it with a center punch so i'll never have a problem knowing what way it need to be weather it makes a differance or not. Last edited by 87 STEPPER; 06-17-2005 at 09:25 PM. |
No No
Yea, my truck was bought new too, too bad it was a couple years before I was born.
![]() Anyway it happened, drove out to the county to help my brother drove back into town went back to the county then was heading home. 70MPH BHHHHHHHHHRRRRRWHHHAAAAAAAAAAAAAAATTTTTTTTTTTT. The front u joint snaped in half!!! It's still in the yoke in sevral peices must have had a hairline crack that would expand under load to cause the vibe. Now my truck is stuck 8 miles away. At least I made it to the motorsports park entrance where I shouldent get a ticket. I just hope nothing got too chewed up or it will be tuesday before I'm able to get another DS.
#8 | |
But, since you've got a 4x2, I'd have to say to start looking elsewhere than the U-joints. Good luck!
Semper Paratus |
#9 | |
No No
I was able to fix it sat night. I took the driveshaft out ran it to the shop put another U-joint in went back and got it going. I ran it up to 4k in 3rd a tad over 100 with no vibration at all now. To give an idea of how bad it was vibrating all the header bolts came loose. I've never had to tighten these ARP bolts since they were installed 3 years ago until this happened.
