Old 07-02-2005, 10:45 PM   #1
s95930
A-Adam A-Adam
s95930's Avatar
Air conditioner problem
I finally replaced the clutch on my AC. It is cooling well. Works fine at idle and around town but when i get out on the highway between 55-65 it freezes up.
Any Ideas?
70 3/4 ton GMC Camper Special
s95930 is offline   Reply With Quote
Old 07-03-2005, 06:25 AM   #2
JimKshortstep4x4
Talking
Does the ac continue to work when the ice forms on the outside of the pipes?
Jim
Old 07-03-2005, 07:59 AM   #3
355
355's Avatar
Do you have condensor coil cooling fans. Do you have a seperate relay to turn on your fans or is it common with your compressor clutch relay. I had the same problem with an old air system. The fan motors are permenant magnet motors, at highway speeds the blades are driven by the wind and the motor becomes a generator. It produced enough power to hold the clutch in and freeze everything up. I added another relay to isolate the fans from the clutch and have had no problems since. Don't ask how long it took to figure this one out. Steve
1969 C10 Long Step,355,700r4w/lockup, HEI,Weiand,750 Performer,1.6 rockers,Camel Humps,Comp 262Extreme,Hedman,2 1/2"pipes, tele/tilt,SunRoof,ps,Disc pb,ac,Cragar,eaton,Corvette style roll pan, Bowtie louvered tail gate,lowered 2/2.
355 is offline   Reply With Quote
Old 07-03-2005, 08:47 AM   #4
s95930
A-Adam A-Adam
s95930's Avatar
Jim
No it slowly looses air flow. I have to tun off the AC and let thaw out.
Old 07-03-2005, 08:49 AM   #5
s95930
A-Adam A-Adam
s95930's Avatar
I have electic fans on my truck. But I don't think it has anything to do with my problem. When the AC is on the cluch on my system does not cycle on and off.
Old 07-04-2005, 05:36 AM   #6
Zeke
Active Member
Could be a low on refrigerent this will cause the evaporator to freeze up. Might try adding a small amount at a time to see if it helps.
1969 C10 350 3spd
1995 GMC 3500 XC 350 dually
When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin
Zeke is offline   Reply With Quote
Old 07-04-2005, 07:37 AM   #7
68C15
blood type; Retumbo
68C15's Avatar
I could be wrong but it sounds like a POA valve problem.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 07-06-2005, 11:28 AM   #8
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
Clutch on our trucks is engaged continuosly when a/c is selected. Evaporator freeze-up in a properly functioning system is prevented by the poa (pilot operated absolute) valve.
I am too new to A/C to arm chair diagnose your problem. You can try asking over in the a/csource forum. Be prepared to provide high/low gauge readings though.
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
Old 07-06-2005, 11:57 AM   #9
Putter
More Cowbell....
Putter's Avatar
I agree with zeke. Check for low refrigerent. That has happened to me before.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 07-07-2005, 01:08 AM   #10
Richard
Freezing can be caused by an overcharge condition, not an undercharge. Low airflow at the evaporator or condenser can also cause freezing. Seeing as you probably have plenty of airflow across the condenser at highway speeds- that is out. Leaves and other crud coming in through the cowl can clog the evap coil. A sticking POA valve is another definite possibility. Check the airflow in the cab at all fan speeds. if it is fine probably the POA.
Richard
Old 07-07-2005, 10:17 AM   #11
Don Smith
I had same problem, replaced expansion valve and it did not cure problem. Tried to find new POA valve but they are not avail. Repaced POA valve with an adjustable valve that cycles the compressor off before evap. freeze up. Works fine now.
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar.
96 Impala SS
97 Monte Carlo
Don Smith is offline   Reply With Quote
Old 07-07-2005, 12:43 PM   #12
grebus1
grebus1's Avatar
Just to be clear (I am an AC novice), the compressor does not cycle on and off if the truck has a factory set-up? If that is so, isn't that unusual compared to the way most vehicles' AC behaves?
'72 Chevy Suburban Custom Deluxe 10, 402/TH400
grebus1 is offline   Reply With Quote
Old 07-07-2005, 02:04 PM   #13
Gene
Gene's Avatar
You ar correct, as I am an A/C novice myself, I asked this same question when I was getting ready to recharge my system after re-installing a new compressor. My system was bone dry and I turned on the A/C and the compressor stayed engaged. This as I was told is normal function for these model year trucks. There is a single switch that supplies power to the compressor clutch and when this switch is made the compressor stays on always.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 07-07-2005, 02:30 PM   #14
chickenwing
You can get a poa eleminator kit that will turn your system to a cycling clutch. Old air products. Around $100.
