Old 07-05-2005, 06:21 PM   #1
Rokcrln
Rokcrln's Avatar
Any ideas for firewall hood hinges?
Does anyone know of a good quality firewall mounted hinge that would work? I need to relocate my hinges from the fenders to the firewall. I have a 71 SWB with a 2" body drop and a "Z"ed frame and in order to get it as low as I want for show I need to section the top inner edge of the fender 2". Right now my fenders lay on my tires before I am at full bump. The problem I run into is the hinge is the only thing in the way of me fixing this problem . Also I want to put stock inner fender wells back in so it is needed for this as well. Any info or pics would be great.
Kevin
Rokcrln is offline   Reply With Quote
Old 07-05-2005, 10:42 PM   #2
67chevemall
67chevemall's Avatar
Could always go this way.
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 07-05-2005, 10:56 PM   #3
bagged91
Out draggin'
bagged91's Avatar
Try getting ahold of Ghettocrewzer on the 67-72 Burb forum. I believe he is using firewall mounted hinges on his burb(layin on 22's...)
L8R - Joe
91 GMC Xcab LB-Bags/bd/caddy clip SOLD
72 C10 Cheyenne Super LWB SOLD
92 GMC K1500 Burb
72 C10 Burb (ex. Cheesewagon)SOLD
72 C20 Burb parts truck
71 C10 Burb "project"
bagged91 is offline   Reply With Quote
Old 07-06-2005, 07:19 AM   #4
Rokcrln
Rokcrln's Avatar
Thanks JoE I will try getting a hold of him. Also thanks for the tilt idea but I am keeping the bone stock look from out side and don't want any extra body lines.
Kevin
Old 07-06-2005, 08:42 AM   #5
jay6891
Car Knocker
jay6891's Avatar
I believe someone has put a front tilt hood on by using the hinges and latch off a mid 80's buick lesaber.(sp) That would move the hinges to the front of the truck.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit.
jay6891 is offline   Reply With Quote
Old 07-06-2005, 08:53 AM   #6
A few 72's
A few 72's's Avatar
To save from reposting the pic's here is a link to a buick setup
http://67-72chevytrucks.com/vboard/s...6&postcount=34
I have a few more that were not posted if you need to see some close ups.
A few 72's is offline   Reply With Quote
Old 07-06-2005, 07:57 PM   #7
Rokcrln
Rokcrln's Avatar
Thanks for the leads but I want mine to open the stock direction. My doors may end up opening in reverse but not the hood. Any door set up picks?
Kevin
Old 07-07-2005, 08:22 AM   #8
AusMarty
here ya go
AusMarty is offline   Reply With Quote
