Java Mechanic
I did sift the FAQs... I didn't find this so I'll ask..
![]() I just aquired a 7 hole instrument panel to replace my 3 hole panel. This will allow me to discard the cute little 3 gauge cluster tacked onto the bottom of dash. Speedo, gas gage and signals are pretty obvious and it look to me like the oil preasure gauge will use the same capilary tube that the little Sunpro aftermarket gauge uses. The ammeter I assume I can also move the wires to from the aftermarket (worst I can do is hook it up backwards... and that should be imediatly obvious.. lol) I can figure out how (especialy with the help I found in the faqs) to fit a tach into the large empty space in the middle and hooking these guys up is fairly trivial. My question is the temp gauge. The aftermarket gauge has a flex shielded cable coming out of it. It appears to me that this is a capilary tube. I figure the regular sensor should be readily available but ... (dum-dum-duh....) will I be able to readily identify the correct wires in the harness or am I going to have to run my own feed from the new sensor to the gauge? ![]() Thanks Y'all!
Keith 11 Lincoln MKT -- Momma's wagon ![]() 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
Java Mechanic
Oh.. ps.. by the way....
Just got my truck through inspection so .. rust be damned.. he's a driver. ![]()
Your dash has a printed circuit on the back--no wires to hook up. You will have to change the wires around in the plug-in. Here is how:
http://www.gmcpauls.com/Tech%20Tips1.htm (scroll down)
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
Java Mechanic
Sweet! Thanks bunches.. I would have gone nuts.. lol
I take it I *do* need to connect the oil capilary line to the stock gauge?
![]() ![]() Join Date: Jul 2002
You will need to change your sensors also forthe water temp and the oil pressure. The gauge use a different sensor than what the idiot lights do.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 08-04-2005 at 01:10 PM. |
![]() ![]() Join Date: Jan 2005
Yes. It connects to the hole at the back of the engine block right behind the intake manifold where your oil pressure switch is mounted.
#7 | |
