Old 08-27-2005, 12:38 AM   #1
rgray71
rgray71's Avatar
Need to find 4bbl intake for sbc
I need a 4 bbl intake for a small block. I broke off a bolt in the thermostat housing. Then while using an easy out I broke it off also. If I cannot remove the broken bolt/easyout in the morning the I am going to replace the intake. Let me know whats is available. It can be cast or aluminum. I will just have to get it pretty fast. Thanks, Rob...
rgray71 is offline   Reply With Quote
Old 08-27-2005, 12:40 AM   #2
rgray71
rgray71's Avatar
I forgot to mention this is a late model motor. It came out of an 83 4x4 pickup....
Old 08-27-2005, 01:33 AM   #3
PMS
I have a factory spread bore cast iron intake if you are interested.
PMS is offline   Reply With Quote
Old 08-27-2005, 01:48 AM   #4
AesC10s
Chevy truck addict
AesC10s's Avatar
I also have a factory spread bore cast iron intake if you are interested Pm Me.
AesC10s is offline   Reply With Quote
Old 08-27-2005, 09:19 AM   #5
rgray71
rgray71's Avatar
PMS pm sent.... AesC10 I will get with you if the other one thats close fall through. Thanks. Hopefully I can get the one on there fixed this morning.
