Old 08-21-2005, 01:20 PM   #1
w314speed
Posi Case 67-72 12 Bolt Truck 3:07-3:40
This is a nice posi case for 67-72 12 bolt truck. This case fits 3:07- 3:40 gears. I would recommend that the clutch discs be replaced or at minimum tighten up. $125 plus shipping.
w314speed is offline   Reply With Quote
Old 08-21-2005, 02:26 PM   #2
uncle
Carriers
PM sent on carriers.
uncle is offline   Reply With Quote
Old 08-21-2005, 04:24 PM   #3
Gary
Gary's Avatar
So what else would a person have to buy in order to use this to turn a non posi 3.08/3.07 into a posi?
Gary is offline   Reply With Quote
Old 08-21-2005, 08:04 PM   #4
w314speed
Install a new set of carrier bearings on the posi case. Transfer the ring gear to the posi case. Install, set the back lash and carrier bearing preload (shims). Basically you remove your non-posi case and install the posi case!!! Thanks, Dan
Old 08-22-2005, 03:32 AM   #5
w314speed
ttt
Old 08-23-2005, 05:52 AM   #6
w314speed
ttt
Old 08-25-2005, 01:40 PM   #7
w314speed
ttt
Old 08-26-2005, 04:27 PM   #8
johnnykool1
3:07-3:40 posi-case
pm sent. later-johnny
johnnykool1 is offline   Reply With Quote
