Old 08-30-2005, 08:39 PM   #1
Daubs
Daubs's Avatar
Front axle turning when hubs unlocked...
Brother drove my truck the other day and I had chance to follow him in my crew cab. Noticed that the front axle was turning as he drove. Made sure the hubs were unlocked and they were. It't not turning at wheel speed, a bit slower, but still turning.
I'm guessing I need to pull the hubs, clean and re-pack them. Suggestions on how to clean em out? Thanks, D.
'72 Chevy K-20 Crate 350, SM465, 4.10's
Daubs is offline   Reply With Quote
Old 08-30-2005, 08:42 PM   #2
qksilver
with a good solvent that has a high flash point. Parts washer is good, blow it dry carefully. I use heavy duty grease on the bearings and a light grease for the hubs themselves. In the winter that heavy grease can make it almost impossible to turn.
Plus did you check your trans fer case shifter. You didn't mention year or type
Steve
qksilver is offline   Reply With Quote
Old 08-30-2005, 09:01 PM   #3
Daubs
Daubs's Avatar
72 k-20 with four speed manual and 205 transfer case backing a 350 v8
Old 08-30-2005, 09:35 PM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
mine does too, it's parasitic drag of the gear oil. I drove mine with the hump out and watched it turn could stop it with my hand. The yoke will turn with the driveshaft removed also.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 08-30-2005, 10:19 PM   #5
qksilver
Yep
Old 08-30-2005, 10:20 PM   #6
4x4Poet
I bet that parasitic drag is good for the front diff, too, since it would keep the oil spread over all the gears and bearings with no significant torque applied that would contribute to wear and tear. Probably keeps the greased spindle bearings in good shape around the stub axles, as well
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 08-30-2005, 11:14 PM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Yup - dunno about the new-fangled trucks, but I think all the old beasts do that.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 08-30-2005, 11:51 PM   #8
1FaastC10
1FaastC10's Avatar
Darwin missed again?
1FaastC10 is offline   Reply With Quote
Old 08-31-2005, 07:58 AM   #9
Daubs
Daubs's Avatar
Parasitic drag, hmmmm. I'm okay with that. I seem to remember my 82 K10 didn't have the drag or turning front axle. I might mess around with this when I get some free time. Glad to know it's nothing I need to worry about right now.
Now that we have moved to Omaha the 72's getting more road time. I can cruise around town doing under 45 mph all day in that truck. And with the glass packs it sounds great. Gotta love the old GM iron!
