Old 09-05-2005, 01:29 PM   #1
454HO
power steering gearbox and pump
Is there anything I should do to the gearbox while I have it off the truck, besides cleaning the gunk off, painting it and replacing the rag joint? Are there any seals or wear items that I should check? It seemed to work fine except for a bad fluid leak which I think was the high pressure hose. I do have a new hose.
And for the pump, same question... anything I should do to it while it's off the truck? I do want to replace the pulley. It has a bad dent on the inside belt groove and will throw the belt. How do I get the pulley off? It looks like a press fit and I may need a special puller.
- Greg
454HO is offline   Reply With Quote
Old 09-06-2005, 01:30 AM   #2
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
I'm not too sure whether or not any seals or o-rings can be replaced without disturbing the worm thrust bearing adjustment.
Yeah, you're right about the pulley. It is pressed in and requires a special tool. You local auto parts store may 'loan' out the pulley remover/installer tool or Harbor Freight sells one for about $10. The second time I installed a pulley using the tool, I used an impact wrench. Being careful, I only wanted to press it in another 32th of an inch. Well, I ended up shearing off the bolt used in tool kit. Oh well, there's an advantage in using 'weak' tools sometimes. BTW, if your power steering pump has a lot of wear and tear, you may want to think about replacing it.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
