Old 09-02-2005, 10:32 PM   #1
4tiresngas
An American Soldier
4tiresngas's Avatar
Help? Wiring Harness Question.
I am installing a new wiring harness on my 69 SWB Step. I do not have the junction box that goes on the passenger fender, but I have one on the way. My question is, what all wires need to be hooked to the junction box? I believe the two in the picture below, but are there any more..maybe coming from the battery? Any help would be really appreciated. Thanks.
Dan
dan.brue@us.army.mil
4tiresngas is offline   Reply With Quote
Old 09-03-2005, 12:21 AM   #2
jhow66
jhow66's Avatar
Only those 2. The red one is your main power wire (black part is a fuse link to protect betweem juction block and fuse panel). Other is the feed for your amp gauge (has a 4 amp fuse in it).
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 09-03-2005, 12:51 AM   #3
GMCPaul
The positive battery cable should have a 16g fusible link wire run from terminal to the junction, the red 12g connects to it and I am assuming that you have a gauge dash and if so the black 18g wire should also connect at the junction block in order for amp gauge to work.
Thats it though for a gauge truck, if non-gauge then no black wire.
GMCPaul
GMCPaul is offline   Reply With Quote
Old 09-03-2005, 03:12 PM   #4
4tiresngas
An American Soldier
4tiresngas's Avatar
Junction Block
GMCPaul
Thanks. GMC Paul, are you saying I need to run a wire from the positive terminal to the junction block also...so three wires attached to it? I do have a gauge dash. When you say fusible link, do I need to buy a fuse housing...what size fuse do I use?
Thanks again. I thought the wiring harness would be labelled. I could not really compare to my old since it was so butchered and I switched from lightsn to gauges.
Dan
Old 09-03-2005, 03:27 PM   #5
john
member #16
john's Avatar
Only the two wires that are shown are needed. Red wire w/fusible link and bl w/4amp fuse. Those wires go to j/block and you need wire from pos terminal to j/block. GMC Paul was saying to put 16ga fuse link in this wire. John
john is offline   Reply With Quote
Old 09-03-2005, 05:37 PM   #6
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
What they said...Only the red to the Battery and the black with the inline fuse. Check the continuity on the fuse though and make sure its good now before the junction block gets there. Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
