Old 09-22-2005, 01:24 PM   #1
Hart_Rod
Hart_Rod's Avatar
Have questions - need pictures!
I've converted my 69 suburban to disc brakes. I've used all 71/72 parts (master cylinder/power booster/proportioning valve......). I ordered a set of 71/72 front brake lines and they are totally different. Are 71/72 trucks they same as 71/72 suburbans? Is there a huge difference in the 69/70 and the 71/72 brake lines. Does anyone have any pictures so I can figure out which ones to order. Thanks in advance.
Rob
Hart_Rod is offline   Reply With Quote
Old 09-23-2005, 01:24 AM   #2
Frizzle Fry
Frizzle Fry's Avatar
Same as the trucks from year to year as far as I know. I put 71-72 discs on my 69 Burb, but I had to use line size reducers at the propo valve.
Frizzle Fry is offline   Reply With Quote
Old 09-23-2005, 11:04 AM   #3
CPNE
Resident Curmudgeon
CPNE's Avatar
Rob
Did you replace the entire cross member? There is a huge difference on where the front brake hoses attach to the hard lines between a 67-70 drum cross member and a 71-up disk crosmember. Perhaps this is your issue? Truck and suburbans share the same components
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
