Old 10-08-2005, 01:16 AM   #1
milehightoyz
AttentionDeficitDisorder
milehightoyz's Avatar
Can I swap the 5 lug axles out of a 72 burb with the 6 lug axles in my 69?
Hi Guys, Im working on a 69 Suburban. I just found a 72 burb at the bone yard and robbed the front disc brake parts (spindle/rotor/calipers/ and prop valve off of it. My guestion is on the rearend. Do I need to swap the entire rearend out or can I just pull the 5 lug axles and swap them into my 6 lug rearend? Any info would be great. Thanks John
milehightoyz is offline   Reply With Quote
Old 10-08-2005, 01:30 AM   #2
BowTieMan
BowTieMan's Avatar
From what I was told is that 69 axles are a little narrower then the late 70 on up axles.
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo
BowTieMan is offline   Reply With Quote
Old 10-08-2005, 07:26 AM   #3
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Just swap the whole rear end assembly. Like said before, there is a difference in the length of the axles, with 69 and earlier being shorter. Supposedly, 70-73 axles are the same length, but (of course) the 73 has leaf springs, instead of coils.
One alternative is to use the later axles, but you have to have a spacer on each end of the axle housing to space out the backing plates, which is why you should just swap the whole thing and be done with it.
Member Nr. 2770
Old 10-08-2005, 09:19 PM   #4
badpeanut
Not a bad nut after all..
badpeanut's Avatar
If you want to keep your '69 rearend (it is the gear ratio you want or a posi, etc) your two options would be to have the axles redrilled for 5-lug or to buy custom 5-lug axles of the correct length.
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 10-09-2005, 05:57 AM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
The spacer deal is a bad idea because the axle bearings still won't ride where they're supposed to on the axles. The brakes may line up afterward, but the machined area on the axle for bearings is still too wide.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 10-09-2005, 09:49 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Tx, I was just gettin ready to say that myself.
