Old 03-16-2006, 01:48 AM   #1
74Chevy74
Coolant leaking in cab....
Ok I noticed some coolant leaking from the heater core in my cab, luckily the carpet was out for dynamat so it was easy to spot, I take it my heater core is going right?
If it does I guess I'll have to explore the vintage air route.....it never ends!
74Chevy74 is offline   Reply With Quote
Old 03-16-2006, 02:05 AM   #2
79GMC_OLDS
79GMC_OLDS's Avatar
Re: Coolant leaking in cab....
yeah that would be your heater core..its easy and cheap to replace so might as well do it now before it makes too much of a mess
79 GMC Sierra 5.9 cummins, nv4500
79GMC_OLDS is offline   Reply With Quote
Old 03-16-2006, 01:03 PM   #3
EJC78
No Life Like Low Life
EJC78's Avatar
that is funny to hear not because your misfortune, but because the same thing happened to me and I went the same route. The best thing about a Vintage Air set up is that the box in the cab is a whole lot less visable. Good luck.
Eric
1978 Chevy Scottsdale
1960 Impala ZZ4
1965 Buick Riviera GS
2011 GMC Sierra Denali
EJC78 is offline   Reply With Quote
Old 03-16-2006, 04:14 PM   #4
72freak
Rottenwood Garage Member
72freak's Avatar
heater core...$35 and a couple of hours
72freak is offline   Reply With Quote
Old 03-17-2006, 12:53 AM   #5
Zoerb
Zoerb's Avatar
if you have messed with the lines in the firewall, one may be leaking inbetween the firewall and the heater core.
2017 Tahoe Premier - Daily
'99 Silverado 2500
Wife's whip- 2020 Equinox Premier
Zoerb is offline   Reply With Quote
Old 03-17-2006, 12:28 PM   #6
HotRod73
HotRod73's Avatar
try going to a small drug store and buying liquid glass... got some for a riviera to repair the blown head gasket, had a cracked heater core and i flushed radiator and put liquid glass in and it sealed it off and now its not cracked (for now, suppose to hold a long time) you have to go to the little independant drug stores to get it though, sometimes they have to order it, you can get some of that crap at walmart in the auto section but its not the real deal... just a suggestion
HotRod73 is offline   Reply With Quote
