Old 12-20-2005, 12:03 AM   #1
bigbuc
Certified Pud Puller
bigbuc's Avatar
ECE drop crossmember
who here has early classics drop crossmember on a long bed? i talked with there tech guy and he said it is possible to run run i was just wondering if anyone had pictures of how they did it.
1997 Silverado extended cab- mpfi conversion, 22" kmc's
1983 C10- some assembly required
99.5 F250 Super Duty 7.3 5" straight pipe, wicked wheel, ts tuner, ccv mod, 4" lift 315/75/16s
bigbuc is offline   Reply With Quote
Old 12-20-2005, 04:56 PM   #2
DM310
Re: ECE drop crossmember
I far as I know there wont be a difference between longbed and shortbed other than the crossmember is under the cab on a shortbed and behind the cab on a long bed.
66 C10 (under construction)
1.5" crossmember drop
2" Z'ed frame
8" rear notch
Watts-link
Bagged
DJM 3" spindles
DM310 is offline   Reply With Quote
Old 12-20-2005, 08:22 PM   #3
powell72
powell72's Avatar
You would need to either have a one piece drive shaft or rig up a mount for the carrier bearing on it.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
