Old 06-07-2002, 07:59 PM   #1
72stik
gas tank problem
Hey out there, My tank, in the cab, had a gas guage that didn't work. Turns out the float was filled, and sank to empty. I pulled it off, cleaned it out, soldered up the holes, and it leaked again. Have given up on trying to fix it for now, and was wondering what alternatives to the stock float can be had (paul) or where I could get a replacement float without the entire sending unit.
Thanks ahead for viewers and responses. Dave
72 C 20 350/4 sp, Ebay bargain!
What's left is nice!
72stik is offline   Reply With Quote
Old 06-07-2002, 09:21 PM   #2
71Chev
71Chev's Avatar
I have a good, stock float from a blazer sender. You can have it for $3.50 priority mail. Not sure if blazer and truck floats are the same, never had a truck sending unit out. Email me.
71 Chevy CST Long Fleet 350/350/3.07 leaf rear.
71Chev is offline   Reply With Quote
Old 06-08-2002, 08:02 AM   #3
A.P.
Black 72 Chevy
A.P.'s Avatar
Check this web site:
http://www.americanclassic.com/asp/d...ype=to&exyear=
Or
Hope this helps.
A.P.
A.P. is offline   Reply With Quote
Old 06-09-2002, 08:00 AM   #4
GMCPaul
We always have these in stock, you may want to examine thwe o-ring and make sure its not cracking or brittle from age, and if a EEC tank make sure all vacuum lines are crack free. When reinstalling sender apply white grease to seal, this aids in sealing and helps the lock ring to rotate into position easily when reinstalling without damage to o-ring seal.
http://www.gmcpauls.com/fuel_tank_&_related.htm
GMCPaul
GMCPaul is offline   Reply With Quote
Old 06-09-2002, 10:28 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I have not looked at the set up in over a year, but would you be able to put a cork on there as a float?
Old 06-09-2002, 10:39 AM   #6
71GMC_3/4T
Weapons Of Construction
71GMC_3/4T's Avatar
I remember several people used wine corks. I think you'd want a real cork one, not the new plastic ones though.
1971 GMC 2500, 402/TH400 4.10 Daily Driver
Lafayette, CO
71GMC_3/4T is offline   Reply With Quote
Old 07-15-2002, 07:20 PM   #7
HvyChevy454
Slowly getting CRSS...
HvyChevy454's Avatar
ive got the same problem again the float fills up /w gas and sinks to empty. this is the sencond flaot i have put in. everytime one gets put in to squeeze it in i think it develops a minute crack that slowly fill up over time. so i want to go to something diiferent, does anybody have any feedback on using a a wine cork or plastic cork or even maybe a bobber? i dotn knwo what would hold up to the gas?
-Nic
Lutz, Fl
My Team Website
The Heavy Chevy Website
  • 72 Cheyenne 10 LWB GM 12-bolt 3.08 w/ Auburn Posi
    91 454 Edel Performer RPM Intake 750 cfm carb Comp Cam 268/.495 Hedman Headers Dual 3'' Exhaust
  • 71 Cheyenne 20 4x4 Fact. A/C PS PB Tilt Currently in the works...
Speak Softly and Carry A Big Block...
There is No replacement for Displacement...
"If everything seems under control, you're just not going fast enough."
- Mario Andretti
HvyChevy454 is offline   Reply With Quote
