I am ready to start on my '67 wood bed. My original idea was to replace the boards and have a liner sprayed in. (not a show truck). Looking at the price of wood kits and then a bed liner I am around $1,000 or more. Is there less quality wood kits out there like treated Fir or something? I could cut my own but looks like a ton of work. I have seen trucks with the sprayed in liner and like the look. Any ideas on what I should put in the bed would be great. Thanks!
Re: Wood bed help
You can get wood for $200-$300 from venders (chevy duty comes to mind.)
And you could reuse the old metal strips. If its just a driver they would look nice with a quick sanding and new paint. Only replace the ones that are mangled.... Kinda need new bolts though, trying to reuse them would be a PITA. Post pics when your done!
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree |
#3 | |
This, is my BOOMSTICK!
Re: Wood bed help
If you want to go the spray liner route just get some sheet metal (or some heavy duty pressure treated wood) and cut it to specs then get that spray lined. I think that this way would be much cheaper then buying reproduction wood product, especially if you are not worried about show quality. Just another idea for you. I was going to buy some Dima-plate (hope I spelled that right) cut it to fit properly and then get it lined. I kind of went back to the wood bed idea, but who knows, I might change my mind again. ![]()
Larry Got rid of my projects for now. 1980 Jeep CJ7 1998 Nissan Sentra (my car) 2001 Toyota Sienna (wife's, of course) Last edited by spencra; 01-05-2006 at 01:19 PM. |
Re: Wood bed help
I have been kicking around the idea of just putting down plywood or diamond plate and having that sprayed also.
#5 | |
Re: Wood bed help
Larry Got rid of my projects for now. 1980 Jeep CJ7 1998 Nissan Sentra (my car) 2001 Toyota Sienna (wife's, of course) Last edited by spencra; 01-05-2006 at 02:35 PM. |
Re: Wood bed help
I would think spray in liner and wood would = lots of headaches. If the wood ever gets wet the liner will seperate.
And I think the liner may not adhere to wood all that well. Before you go that route I'd call the bedliner company your going to use and get their input. You might be better off getting an all metal bed, or using the plastic insert bedliner.
1971 Shortbed 350/350 w/ Posi-traction 3:73's 1996 Chevy Silverado TJ in Springfield, Virginia Likes old Chevy trucks Drinks Miller MGD ![]() |
![]() Join Date: Mar 2005
Re: Wood bed help
i replaced the wood floor in mine with a sheet of 3/16" plate.i used 3/4" square tubing in the place of the wood floor to shim up the plate and used 1x1x3/16" angle iron on the sides to replicate the thin angle iron strips on the bed sides.the other reason for the angle iron on the bed sides is a 4'x8' sheet of plate is not wide enough to cover the floor from side to side,since the inside of my step bed is 50". you didn't say if your was a fleetside or step,but would work out the same except for more material.i had around $200.00 in material,now i'm going to get a bed liner sprayed in it. hope this helps!
Re: Wood bed help
That's some great info guys! Thanks a ton.
Re: Wood bed help
lilred
that sounds like one rock solid bed!!!
