Old 02-02-2006, 03:30 PM   #1
ACES
Life is a gamble
ACES's Avatar
12 bolt gasket replacement
I am replacing the gasket on my 12 bolt today. I've never done this before. I did not find any metal shavings inside. I scraped the old gasket off and have put the new Fel Pro gasket and cover one. I have not tightened it. How tight should I turn the bolts?
How much oil should I add?
I got 80W-90 Gear lubricant.
I'm guessing that I put it in through the hole in the top where the hose is.
The hose looks terrible too. I should probably replace it while I'm there.
Any words of advice or warning?
I took a couple of pics of the differential. I'll post them in a little while.
1970 Orange CST C-10 w/350, posi, Longbed
The torpid artist seeks inspiration at any cost, by virtue or by vice, by friend or by fiend, by prayer or by wine.
-- Ralph Waldo Emerson
ACES is offline   Reply With Quote
Old 02-02-2006, 03:43 PM   #2
68/72parts
Re: 12 bolt gasket replacement
I would recommend using a good quality silicone RTV instead of the gasket. It will seal better and not leak in the long run if applied properly. As for amount of fluid you pull out the check plug, hopefully you did this already? and fill the diff until fluid just starts to come out of the hole, make sure the truck is reasonably level first. 80-90w will work fine or a good synthetic would be my choice. When you apply the silicone you dont need much just a nice 1/4inch thick bead all the way around. make sure to kleen off the excess before it dries.
68/72parts is offline   Reply With Quote
Old 02-02-2006, 04:07 PM   #3
67ChevyRedneck
67ChevyRedneck's Avatar
I agree, I just did this last weekend. And yes, if you have a limited slip rear, you do need the special "limited slip, or Positraction" rearend gear oil. If I remember right I bought two of the smaller bottles of fluid and it was enough, I think they were 1 quart bottles??? Memory sucks.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 02-02-2006, 03:56 PM   #4
ACES
Life is a gamble
ACES's Avatar
68/72 parts -I have located the check plug. It has an orange tag on it that says to only put gear oil recommended for limited slip differential in. I'm gonna have to get some different oil. I'll look for some silicone RTV while I'm there.
Old 02-02-2006, 04:27 PM   #5
68haywagon
I'm watching you!
I used a gasket, no leaks at all. I would not use silicone, because when I need to get in there again I don't feel like scraping and peeling silicone. I agree about how much to put in though.
Mike
2012 Chevrolet Silverado 1500 Z71 4WD
1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP)
1992 Chevrolet S10 - LS swap project
1968 Chevrolet C-10 longbed fleetside - sold
68haywagon is offline   Reply With Quote
Old 02-02-2006, 04:42 PM   #6
MrC1
Dork For Days
MrC1's Avatar
You can also buy limited slip additive separately, but you shouldn't need it. There are many 80-120 weight oils out there made for limited slip diffs, probably most of what you find on the shelf at a parts store.
Anybody know what hose he's talking about? That scares the heck outta me!
1972 C20, 402/700R4 - My first classic truck, bought in September 2005. 85% transformed from "Farm" to "Cool" status!
1970 Dodge Challenger 440, 4sp (my other toy) 12.67 @ 117 MPH, with a pathetic 2.022 60'
2007 Dodge Charger SRT-8
2008 Cadillac CTS
All-American garage, baby!
MrC1 is offline   Reply With Quote
Old 02-02-2006, 04:43 PM   #7
cdowns
cdowns's Avatar
it would be ALOT better if you used asynthetic gearoil such as royal purple or moibil1 they're rated for posi's so you don't need the additive// the biggest cause of leaking after removing and replacing a diff cover is overtightening max of agout 12-15 ft lbs// overtightening causes boltholes in the cover to bulge out causeing leaks
Old 02-02-2006, 04:41 PM   #8
ACES
Life is a gamble
ACES's Avatar
well guys, I'm back from Advance Auto. I've got the Silicone RTV and two bottles of Synthetic gear oil for Limited slip. I think since I've already got the gasket on there, I'm gonna leave it there, but if I have problems I'm gonna take it off and do the Silicone.
Old 02-02-2006, 04:41 PM   #9
ACES
Life is a gamble
ACES's Avatar
How tight should the bolts be?
Old 02-02-2006, 04:45 PM   #10
bighead
Vent hose.
bighead is offline   Reply With Quote
Old 02-02-2006, 04:52 PM   #11
67ChevyRedneck
Originally Posted by bighead
Vent hose.
It runs from the top of the differential over to the driverside frame rail... or so its supposed to....
Jesse James
Project "On a Dime"
Old 02-02-2006, 05:31 PM   #12
jimfulco
I hate silicone. If you want an easily removable gasket, paint both sides with Permatex #3 Aviation Sealer or Permatex Super 300 (in the little white plastic can). It won't leak unless the cover is distorted, and it will come off easily with an easy pry with a screwdriver. Another coat of goo, and it will seal again. Gas and oil won't touch it, but alcohol cleans it up easily.
I glue gaskets to the cover with yellow 3M so they won't come loose, and use the Permatex on the other side so it'll come loose when I want it to.
jimfulco is offline   Reply With Quote
Old 02-02-2006, 07:27 PM   #13
70STOVEBOLT
70STOVEBOLT's Avatar
Also, two of the bolts require a thread sealant, as they go all the way through the housing and are below the lube level. I forget which two they are, but if you don't put thread sealant on them, you will get a leak there.
70STOVEBOLT is offline   Reply With Quote
Old 02-03-2006, 10:31 AM   #14
67ChevyRedneck
Crap, y'all tell me this now?
Jesse James
Project "On a Dime"
Old 02-03-2006, 10:04 AM   #15
ACES
Life is a gamble
ACES's Avatar
Does anyone know which two bolts require thread sealant?
Old 02-03-2006, 10:07 AM   #16
cdowns
cdowns's Avatar
i always put sealant on all bolts in the rear cover
