Old 01-25-2006, 09:19 PM   #1
67chevytodd
Junior Member
60' Front suspension?
I have a good 60' apache c-20 that I am starting to restore. I have several 1/2 ton coil spring rearends to swap out the 8 bolt low geared rearend, but I was wondering about the frontend. The 60'- 62' have a different front suspension than th 63'-72'. Will the 67'-72' fronts bolt under the 60' or can I put 1/2 ton spindles and 5 bolt hubs on the old 3/4 front ? Please help, Thanks Todd
Old Chevys never die they are just reborn!
67chevytodd is offline   Reply With Quote
Old 01-26-2006, 03:36 AM   #2
1BAD64
1BAD64's Avatar
Re: 60' Front suspension?
mine has a 77 frontend in it . i just swapped upper and lower a-arms,spendles and hubs. bolted right up.
1BAD64 is offline   Reply With Quote
Old 01-26-2006, 09:19 PM   #3
zenish
try asking at www.chevytalk.com
1964 c10 short step
1962 econoline van
1989 rs camaro
2006 yamaha vino 125
1975 goldwing
zenish is offline   Reply With Quote
