Apache Club
going back together with cam
went and got a new cam and timing gear drive tonight
![]() Part Number: 100172 Grind Number: 274 HO6 Engine Identification: Start Yr. End Yr. Make Cyl Description 1957 1987 CHEVROLET 8 ROUGH IDLE, MODERATE PERFORMANCE USAGE, GOOD LOW AND MID-RANGE TORQUE AND HP, MILD BRACKET RACING, AUTO TRANS W/2500+ CONVERTER, 2600-3000 CRUISE RPM, 8.75 TO 10.0 COMPRESSION RATIO ADVISED. BASIC RPM 2200-5200 Engine Size Configuration 262-400 C.I. V Valve Setting: Intake .000 Exhaust .000 HOT Lift: Intake @Cam 300 @Valve 450 All Lifts are based on zero lash and theoretical rocker arm ratios. Exhaust @ Cam 300 @Valve 450 Rocker Arm Ratio 1.50 Cam Timing: TAPPET @--- Lift: Opens Closes ADV Duration Intake --- --- 274 ° Exhaust --- --- 274 ° Spring Requirements: Triple Dual Outer Inner Part Number 96802 Loads Closed 107 LBS @ 1.800 or 1 13/16 Open 271 LBS @ 1.370 Recommended RPM range with matching components Minimum RPM 1800 Maximum RPM 5800 Valve Float 6400 Cam Timing: TAPPET @.050 Lift: Opens Closes Max Lift Duration Intake 7 BTDC 31 ABDC 102 218 ° Exhaust 39 BBDC (1) BTDC 110 218 °
![]() ![]() My Trucks Apache Sitting Idle MySpace Project Dad's Truck (74 C-10 to K-10 conversion) ![]() |
Re: going back together with cam
You went a bit more radical than I did.
I am using the Edelbrock Preformer-Plus Cam Kit (Cat# 2102) with the Edelbrock manifold and 4bbl. Mine is a daily driver though. Cadman
56 GMC 1922 Dodge Rat Roadster 89 Gray Allante 90 Red Allante Turkey Run Photographer http://www.turkeyrun.com/photo_gallery.html |
Apache Club
mine is just a weekend warrior so i did go a lil radical with it i called jeggs and crane told them the specs on the motor , trans, gears ,tire size they both came back with this cam so i figured i would see if they new what they were talking about hopefully it will be running tonight
Apache Club
i busted the motor off tonight i put the cam in last sunday but have had the flu and 2 ear infections so i let it sit all week finally couldnt take it any more and got it all back together tonight if my cold will let me ill finish tiying it all up tomorrow set timing and such
#5 | |
River life......
Apache Club
sounds like normal fun
