Old 12-15-2005, 10:36 PM   #1
rencher2
Question U-joint for steering shaft coupling?69 K20
My body lift is pretty tall & im a little concerned about the stress on the coupling. Does anyone make a u-joint to replace it? I'm open to any suggestions.
rencher2 is offline   Reply With Quote
Old 12-16-2005, 12:49 AM   #2
69TowRig
Re: U-joint for steering shaft coupling?69 K20
I would check out Borgeson:
http://www.borgeson.com/
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
Old 12-16-2005, 01:02 AM   #3
redneck_motorsports
redneck_motorsports's Avatar
Thats wshere I got mine for my 67. Ditch the rag and use two u-joints, problem solved.
Catfish
I have alot of stuff, some of it is here
redneck_motorsports is offline   Reply With Quote
Old 12-16-2005, 01:50 AM   #4
rencher2
You guys wouldnt happen to have a part # would you?
Old 12-16-2005, 09:03 AM   #5
dennislbrooks
dennislbrooks's Avatar
another choice that has them --expensive little dudes
http://www.speedwaymotors.com/error/....com/index.asp
dennislbrooks is offline   Reply With Quote
Old 12-16-2005, 11:39 AM   #6
Yukon Jack
Yukon Jack's Avatar
I'm using one from Borgeson - here is a link with info for you.
http://67-72chevytrucks.com/vboard/s...d.php?t=101550
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 12-16-2005, 02:41 PM   #7
Mudder
Mudder's Avatar
Mine came out a Chrysler minivan and it is welded in. I had two at one time but was having trouble with it binding. We took one of them out and have had no problems since.
Mudder is offline   Reply With Quote
Old 12-17-2005, 05:05 PM   #8
454_72_4X4
454_72_4X4's Avatar
I used one from a Chevy Astro minivan on my S-10. I have another one I'm gonna use for my 72 someday.
You have to lengthen the shaft but it has real u-joints and the splines should line up.
I think Chevy had two different spline sizes though?
Pic of iton the S10;
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 12-29-2005, 05:15 PM   #9
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Little toyota pick-ups have then also with u-joints on both sides..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 02-11-2006, 05:45 PM   #10
4x4Poet
If you go Borgeson, FlamingRiver, etc., get a vibration reducer joint so the road-induced vibrations don't reach the steering wheel. The rag joint is imprecise, but it does a good job absorbing vibrations– unlike straight yokes/joints. And be sure to install any set screws with locktite so you don't lose attachment while on the road.
The Borgeson site should have a section for measuring your set up for the length you need. Know your male shaft diameters & spline counts and be sure you are thru with body lift changes or cab support changes so the length is right till the next major change.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 02-12-2006, 12:55 AM   #11
1969 GMC
1969 GMC's Avatar
the "small" Jeep Cherokees (XJ) have ujoint steering shafts too.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
