Old 02-08-2006, 07:10 PM   #1
TX72K5
Junior Member
TX72K5's Avatar
Why the different axles lengths?
I am sure this has been asked and answered more than once on here, but I haven't seen it in the recent posts. I think I know the answer, but I'll ask anyways.
Why is the front axle longer than the rear axle on the 4x4's? Also, what would be the correct spacing on the rear to make them look even?
Thanks, Mike
TX72K5 is offline   Reply With Quote
Old 02-08-2006, 11:26 PM   #2
krue
Designated A-hole!
krue's Avatar
Re: Why the different axles lengths?
What year you got? I know the 70 1/2 up 2wd (which should be the same as the 4wd) rear ends are 1.5 inches wider than the earlier ones. Why? I don't know.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 02-09-2006, 12:56 AM   #3
jhow66
jhow66's Avatar
Thanks, Mike
Front axle is a Dana-rear a GM 12 bolt--you need 1 1/2" spacer for each side to make the rear track the same as the front track. My son (orangeuavol) did this on his blazer. He found a new set on ebay for $80 (6-lug). Be sure and use the same wheels all the way around for even track. No need to change studs as the spacers have them and the holes to bolt to studs on axles.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 02-09-2006, 01:03 AM   #4
badpeanut
Not a bad nut after all..
badpeanut's Avatar
The wider front than rear axle width continued on into the '73-up trucks. I'm also interested in the reason why...
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 02-09-2006, 02:26 AM   #5
69TowRig
I think one of the reasons why I generally like the look of Dodge and import trucks is because the front and rear track widths are the same or nearly so. GM and Ford both had different widths.
I really want to make mine wider in the rear, I don't like the "tucked in" look. Good tip on the 1.5" adapters. Anyone have any experience with how long the axle bearings last with those?
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
Old 02-09-2006, 03:14 AM   #6
TX72K5
Junior Member
TX72K5's Avatar
I have a 1972 Blazer. I was told in the past they made them different lengths, so they would track different in mud, snow and so on for better traction. Of course, I dont know if that is the real reason. Thanks for the spacer info. Mike
Old 02-09-2006, 07:41 AM   #7
vtblazer
vtblazer's Avatar
Same as what I had heard.
Any other "reasons" ??
vtblazer is offline   Reply With Quote
Old 02-09-2006, 11:05 AM   #8
Chris_T
I've heard it was to improve turning radius .. no idea if this is true
Chris_T is offline   Reply With Quote
Old 02-09-2006, 11:41 AM   #9
2wdBlazer
The Blazer King
2wdBlazer's Avatar
I have a 14 Bolt FF rear and mine tracks Even.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 02-09-2006, 09:03 PM   #10
69TowRig
That would have no effect. The wheelbase and the angle that the wheels turn in either direction are the only constraints to curb-to-curb turning radius.
-Chris
Old 02-10-2006, 11:29 AM   #11
71RestoRod
71RestoRod's Avatar
I always figured it was just to cut costs by using the same width 12-bolt as the 2WD trucks.
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod
71RestoRod is offline   Reply With Quote
Old 02-11-2006, 07:03 PM   #12
Medicanman71
Medicanman71's Avatar
Which trucks came with 12bolts and which came with 10 bolts what made the difference?
http://cgi.ebay.com/ebaymotors/GMC-C...QQcmdZViewItem
is this the guy, are these the spacers?
Medicanman71 is offline   Reply With Quote
Old 02-11-2006, 08:12 PM   #13
ClassicStyle
ClassicStyle's Avatar
i heard somewhere it helped them turn easier. being that the hind end was narrower then the front they didnt push so much.
-Cameron
1972 Dark blue, Cst, Highlander
ClassicStyle is offline   Reply With Quote
Old 02-12-2006, 11:14 AM   #14
69TowRig
Those will not fit because of the metric studs. You would need spacers with SAE studs, unless you wanted to run metric in the rear
67-72 trucks did not come with 10-bolts, those arrived during the following generation in the late 70's.
-Chris
Old 02-12-2006, 04:44 PM   #15
Medicanman71
thank you!
Old 02-15-2006, 01:09 PM   #16
mrmaxrebo
Yep that right. The front is wider than the rear so your tires don't track in the same tracks as each other. My dad worked in a 4x4 shop when I was younger. He told me thats why they did it. As for the turning...I could see how it would allow you to turn the front wheels that much more.
1972 K/5 Blazer CST - $1 Beast
1993 4.3L S-10 Ext Cab. - 3/4th 350
mrmaxrebo is offline   Reply With Quote
Old 02-15-2006, 01:31 PM   #17
Medicanman71
i want spacers!
Old 02-15-2006, 06:14 PM   #18
70rs/ss
70rs/ss's Avatar
The better maybe even the "right" way to do this would be to get different offsets on your wheels. Spacers are not a great idea, especially 1 1/2". If you get 3" backspace and 41/2" backspace you end up with the same effect without the extra stress on studs and bearings. Just my thoughts.
70rs/ss is offline   Reply With Quote
Old 02-15-2006, 06:17 PM   #19
Tynee
I miss this truck.
Tynee's Avatar
But then you have to take the tires off the rims to rotate them. Neitherthat, nor the spacers sounds like a good option to me.
How much work is it to swap one axle or the other? Can it be done in a day, if the proper donor axle is used (say, complete from drum to drum, or rotor to rotor)?
'07 GMC Acadia SLT. Sweet ride.
'08 Crew Cab Z-71 short bed. Really like this truck A LOT.
Tynee is offline   Reply With Quote
Old 02-15-2006, 09:48 PM   #20
Medicanman71
hahaha, for get swaping axles for a few inches... that's crazy
I just need to get new rims and keep the stock/old ones.
Old 02-15-2006, 11:01 PM   #21
71RestoRod
71RestoRod's Avatar
I'm also aware of the double track theory and I think it has some weight but I've also heard from knowledable old guys that this is also an old wives tale.
One way to swap if you want matched width without spacers is to swap with a D60 in the front and a van 8-lug 14-bolt in the rear which puts you at about 70" flange to flange. This will set you about three inches wider than a 1/2 ton D44 front.
Here's the ultimate in decadence... I didn't want to build mine up as a 3/4 or 1 ton. Too heavy for what I was after and you really need 35" or better to have any sort of clearance under a 14-bolt rear.
I too didn't want spacers or mismatched offsets... My 12-bolt was dead and I didn't think beafy enough to warrrent a rebuild.
In a moment of weakness I called Dynatrac and spec'd out this matched-width D60 rear with disks and a Powr-Loc 70% limited slip. With 16x8" rims and metric 33"s the tires fall perfectly at the edge of the wheel wells. Just the way I wanted it. I wouldn't recommend this for the faint of heart... cost me almost twice as much as I originally paid for the Blazer... Please don't flame me for building with a check book... I spent a lot of my blood and sweat on it too.
This truck handles way better than it used to... but I've got lots of mods into it so I can't say if the matched track has anything to do with it.
This pic has a pretty good angle on the rear...
