Old 10-17-2005, 08:06 PM   #1
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
6 Cylinder in a 4x4?
What does it take to go from a V-8 to a 6 cylinder in a 4x4? are the crossmembers the same? Are the stands the same as a 2 wheel drive?
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 10-17-2005, 08:13 PM   #2
BLAZERMAN
BLAZERMAN's Avatar
Re: 6 Cylinder in a 4x4?
Sorry, I thought I posted this in the 4x4 section.
Old 10-18-2005, 12:09 AM   #3
teeitup
Just like to part out trucks!!
teeitup's Avatar
Rob, the crossmember is different than a V8, I got one down here somewhere. Thanks Randy
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 10-18-2005, 01:49 AM   #4
4x4Poet
btt for more specific info, please.
Another board member turned me onto the idea of a turbo'd 292.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 10-18-2005, 04:51 AM   #5
krue
Designated A-hole!
krue's Avatar
I'd like to know myself. I'm thinking about buying a 72 blazer with no engine. It had a 350, I have a 250 laying around. What's it gonna take to throw it in there?
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 10-18-2005, 05:42 AM   #6
'68OrangeSunshine
'68OrangeSunshine's Avatar
[No names on location, of course. ]
I understand there is a book, "Maximum Boost", by Corky Bell that is a must-read. Don't have it yet myself.
I have a '72 K/5 rolling frame I intend on running a normally-aspirated 292 in. I have a Holley 390 left over since I put an Ed$elbrock 500 on the L6 in my stepside. I still need to acquire an SM 465/NP205 combo. Also will be converting a KE automatic truck to KS manual. Guess I'll also need to get the X-member.
Also thinking of powering a '67 K/10 suburban with a 292 on turbo. Big project, very spendy, but maybe not as costly as operation costs plus rebuild of a scorched 454. (With gas near $3/gal). Sub has a TH350 now, thinking of a 700R4 for the OD. Not sure how effective a switch-on-the-fly gas/propane set-up could be, but that's another bubble of the Suburban pipe dream.
Old 10-18-2005, 06:44 PM   #7
charlieo
I've got a 72 4x4 that originally had a 250-6 in it & I went directly to a sb 400 no changing anything ! Except getting used to 375 hp !!
charlieo is offline   Reply With Quote
Old 10-19-2005, 01:12 PM   #8
CUSTOM/10
CUSTOM/10's Avatar
I don't know about the 250 crossmembers, but the 292 crossmember is different, and is specific to the 292. The motor mounts are offset from each other. If anyone is interested I have a very nice 292 4x4 crossmember that I'll be removing shortly to install a 350.
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 10-20-2005, 12:09 AM   #9
Hmmm,Don`t need to change crossmembers on 2wds,so....??
Old 10-20-2005, 06:26 AM   #10
'68OrangeSunshine
Custom/10: PM sent
Old 10-20-2005, 01:38 PM   #11
CUSTOM/10
CUSTOM/10's Avatar
Originally Posted by '68OrangeSunshine
Custom/10: PM sent
Returned PM
Gary
72 SWB 4x4
My 72 SWB Build
Old 12-16-2005, 10:12 AM   #12
70blazerpickup
the small block crossmember and the inline 6 cross members are the same. i had a 250 6 and i pulled it out and dropped a 350 right in. the only thing i had to change was the clutch linkage and the throttle linkage.
70blazerpickup is offline   Reply With Quote
Old 12-16-2005, 04:08 PM   #13
'68OrangeSunshine
The 292 L6 required its own unique [almost diagonal] crossmember in 4wd only. The C/series could use the regular frame rails. 292s have an off-center mount configuration -- GM moved the passenger-side motor mount forward, maybe to counteract the greater torque of the 292 (?) -- the fuel pump went to the center where the motor mount was on the 230/250s. The smaller L6s had symmetrical mounts. On the 2wd the more forward right hand mount can connect to the frame rails, on the 4wd, it needs a special crossmember.
Old 12-16-2005, 08:08 PM   #14
CraigS
I currently have a 454 in my '72 4x4 and am thinking of a turbo 292. Does it really need a new crossmember or can't I just fab up mounts and weld them to the frame?
72 GMC K20, 454, TH350
00 GMC Yukon
66 Ford Bronco
CraigS is offline   Reply With Quote
Old 12-17-2005, 06:17 AM   #15
'68OrangeSunshine
If you can weld, you can fab anything. I was lucky enough to get Custom/10's 292 crossmember, so I can get nearer to a factory style install.
Old 02-11-2006, 07:04 PM   #16
4x4Poet
Since 73up(-87/91?) GM light truck, V8 engine crossmembers bolt into 67-72 4x4s with just a little drilling and trimming, wouldn't 73up 292 4x4 crossmembers also bolt in? IOW, wouldn't obtaining a 292 engine crossmember for a 67-72 4x4 only entail a simple junkyard search for a GM, 292-equipped pickup or burb? Missing the 292, of course.
Old 02-12-2006, 05:00 AM   #17
'68OrangeSunshine
I couldn't tell ya pal. For me the Chevy Truck world is flat -- bounded on the East by 1967 and stretching far to the West until 1972. The rest is a mystery, but I've heard if you go beyond that you fall off the edge.
Old 02-15-2006, 02:21 PM   #18
shelby987
shelby987's Avatar
Would just like to chime in, my truck has a 250 in it.....and in the mud the column shifter, and the L6 make for an awesome combination(real quick r-1st shifts...and not bogged down in the front end). I have a custom built 250 in the garage waiting its chance to tear up some mud as well......I would have gone with a 292 for torque, but the price for the built 250 was too good to pass up.
1969 SS 350 Camaro Sold 2008
1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's
1980 Chevy Malibu 2 dr Sold 2007
1993 Olds. Cutlass Ciera Wagon Traded 2006
2003 Saturn L200 w/5pd. D/D
My list spans 5 decades with One common thread.....GM!
shelby987 is offline   Reply With Quote
Old 02-27-2006, 10:58 PM   #19
Chevrolet4x4s
Chevrolet4x4s's Avatar
Lots and lots of duct tape .......did i mention duct tape
Shane
1993 K1500 350 5 speed
1985 K10 Silverado Vortec 406 5 speed (in body shop)
"I been drivin' this '85 pickup truck Them buddies of mine call it a bucket of rust She's a little beat up but she still runs like the wind Yeah, kinda like me I been banged and bruisedBeen around the block a time or two But I'm runnin' like new goin' places I never been
No, I ain't broke I'm just broken in"
1963 Dodge Townwagon(its amazng what 30 years and zero miles will do to a vehicle )
Member#20327
Chevrolet4x4s is offline   Reply With Quote
Old 02-28-2006, 10:10 AM   #20
1967k30
1967k30's Avatar
I too an considering going to a 292 w/ a Clifford kit. But was wondering what kind of power I will have? I'm also getting a 402,just because the price was right . I need to decide which to run. I currently have a gutless 350 that burns an unreal ammount of fuel .
01 2500 Duramax,6spd,4x4,Not stock. Estimated
550rwhp/1100rwfp on fuel only.
03 3500 Duramax,6spd,4x4,Pac-Brake,not stock Estimated 500rwhp/1000rwfp fuel only
67 K10 in many pieces
Little Brothers truck
67 K20 Cummins 12V/NV4500/205,
D60/Eaton w/ Detroit,37" Xterrains,crossover steering,
Future plans,Twins and lots of fuel.
1967k30 is offline   Reply With Quote
Old 03-03-2006, 03:19 AM   #21
'68OrangeSunshine
1967K/30: I would suggest an Offy intake instead of the Clifford. The Offy is reputed to be better at low RPMs and low end torque as you find in trail running, the Clifford intake is more designed to flow better at high RPMs, such as one encounters when dragging a 1/4 mile. Clifford headers do rule however. I'm still using a pair I bought in 1978 on my '68 Stepside. Second engine, some repairs -- resectioned crushed #5 downtube, resurfaced intake flange, but more or less the same pipes.
I use an Offy intake, Edelbrock 500 CFM 1404 Carb, and Clifford headers on my 292.
