big block 2wd auto. trans. linkage f/s
![]() Last edited by billsbowtie; 03-04-2006 at 04:27 PM. |
Senoir Member
Re: big block 2wd auto. trans. linkage f/s
How much $$$?
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4" 70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010 70 GMC Restoration Pictures http://67-72chevytrucks.com/gallery/...00&ppuser=4424 |
![]() Join Date: Feb 2004
will that work on a small block?
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
it came off of a factory bb truck that had been change to sb with a 350 trans. it was working on it.
![]() Join Date: Apr 2000
not the same as 4x4, i belive it is the same as a sb truck with a t400, if that helps
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
I don't see very many 4X4's around here but that sure looks like 2wd BBC with T400. The sbc normally has the frame mount with wider mounting ears. Teeitup had a picture posted not too long ago of the sbc linkage.
I have several BBC T400 linkages. I will look and post any differences.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow Last edited by Bob Moore; 03-04-2006 at 10:09 PM. |
