Old 04-07-2006, 09:57 AM   #1
AWEGS72
AWEGS72's Avatar
Wrong ball joints?
I bought new lowering spindles for my 72 from GMCPAUL'S and was installing them last night. I put in new upper and lower ball joints while I was doing the job. I had the spindle in place,and was torquing down the upper ball joint but can't get it tight enough to see the hole for the cotter pin to go through. I can't get it tightened down enough it seems.The I looked at the other new one I have for the other side and its identical. I put the rest of it together and went to the other side,same thing on the other side too.
Anybody run into this problem? I called the parts place and they verified that they gave me the correct ones. Any thoughts,ideas would be appreciated.
Thanks,
Andy
AWEGS72 is offline   Reply With Quote
Old 04-07-2006, 11:46 AM   #2
matt67350
matt67350's Avatar
Re: Wrong ball joints?
Try the old spindle on the new ball joint. You may have the wrong year new spindles.
69 swb stepside, rebuild and upgrade in progress
matt67350 is offline   Reply With Quote
Old 04-07-2006, 04:28 PM   #3
OLDROCK&ROLLER
OLDROCK&ROLLER's Avatar
some spindles are for 73 & up trucks and require ball joints from these years. Mine did but I can't remember if it was the bottom or the top joint.
72 CHEYENNE 10 SUPER
468/400/3.73
OLDROCK&ROLLER is offline   Reply With Quote
Old 04-07-2006, 05:16 PM   #4
dennislbrooks
dennislbrooks's Avatar
I believe the correct upper for a 71-72 spindle is a Moog K6124. Lower is K6117,
dennislbrooks is offline   Reply With Quote
