Dana 44 Upper Ball Joint Lube???
I just replaced ball joints on my Dana 44 and found out that the axles will not go in with the grease fitting installed on the upper ball joint. The ball joint came with a plug which I will use. My question is, should I grease the ball joint before plugging it or just leave the factory grease alone? Or is there another way to get grease into it without removing the axle?
Eric 1969 K20, 465/205 package |
![]() Join Date: May 2003
Re: Dana 44 Upper Ball Joint Lube???
I would grease it just to be on the safe side. Mooge makes upper ball joints with a grease fitting that stick out from the side so it can be greased any time. ( Just for future info )
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
Born Psycho
![]() Join Date: Feb 2001
definitly grease them then re-install the plug.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
