Old 05-03-2006, 02:15 PM   #1
motocrosschump
Header Wrap
Can you wrap headers installed on the truck?
The Cause and The Reason:
The Cause is starter heat soak
The Reason, headers are welded to pipes.
2006 Titan SE Crew Cab Daily Driver
2005 Mazda Tribute (Wifes car)
1969 C10 SWB 350/3 Fleet "Max"
1969 Chevelle 2 door 350/3
motocrosschump is offline   Reply With Quote
Old 05-03-2006, 02:21 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Header Wrap
You are WAY better off with a heat shield.
Header wrap will shorten the life of a header by at least 50%... if not more.
You oughta look into a starter too.
Old 05-03-2006, 02:32 PM   #3
shifty
Questionable
shifty's Avatar
Re: Header Wrap
header wrap is supposed to hold moisture to the header and cause them to rust out exponentially faster.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
