Old 06-01-2006, 12:16 AM   #1
Capitol68
Capitol68's Avatar
Gas gauge at 3 o'clock
I need some help here, my gauge is sitting at 3 o'clock. I thought it might be the wire which goes under the rocker, spliced into it, but that wasnt it. Guessing gas level sucks, ran out of gas once, rather not do it again.
Also, the dash panel, it should come right off right ? it might be stuck, just didnt want to break anything trying to get it off to check wiring and change bulbs.
Thanks for the help
Mark
'68 Fleet LWB
orig 307 .030 over
GM Hei/w Accel Super coil
orig. stock TH 400.
_______________________
“What we do for ourselves dies with us. What we do for others and the world remains and is immortal.”
Albert Pine
English author d.1851
Capitol68 is offline   Reply With Quote
Old 06-01-2006, 03:43 AM   #2
RicksTrucks
RicksTrucks's Avatar
Re: Gas gauge at 3 o'clock
Could be the fuel sending unit that is in the tank
68 Short Stepside C-10
69 SWB C-10
70 Flatbed C-20
70 LWB C-20 BB402
70 LWB C-10 CST
70 LWB C-10 CST
71 Short Stepside Cheyenne C-10
72 LWB C-10
72 Blazer 4x4 4spd
95 Jeep Cherokee 4x4
RicksTrucks is offline   Reply With Quote
Old 06-01-2006, 09:29 AM   #3
jhow66
jhow66's Avatar
Thanks for the help
Mark
Check this wire from here to tank-it is broken or disconnected from tank:
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 06-01-2006, 10:46 AM   #4
70c10
67-72 Addict!
70c10's Avatar
Thanks for the help
Mark
Don't forget to unhook the harness, oil pressure line, speedo cable and headlight switch rod.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 06-01-2006, 01:07 PM   #5
Capitol68
Capitol68's Avatar
Ok thanks guys, I will look here in a litte while, its raining here. I ll keep yall informed
Mark
'68 Fleet LWB
orig 307 .030 over
orig. stock TH 400.
Albert Pine
