Old 07-28-2002, 11:42 AM   #1
HvyChevy454
Slowly getting CRSS...
HvyChevy454's Avatar
Exclamation Finishing paint question!
ok i plan to go to my first show next weekend but i need to fill in some chips in the paint. also i know after painting you need to wetsand and buff. we had to respray the front due to a run in the paint that got sanded to far down. now ther is a seem and a little bit of orange peel from the over spray somehow. my friend was suposed to show me how to and help buff and clean up the paint. i have the paint, along w/ a can marked 50% activator and another can marked 30% hardener. how to i mix there to fill in the chips in the paint?
also i know that i need to wet sand the paint and buff it to get the glossy finish but what grit paper 1500? then how do i buff i dotn use polish and rag do i? What kind of compound to do i need.
I need to get this doen this week so i will be able to go to my 1st show and its a big one too so i realy dotn wanna miss it and my g/f grandparents club promotes the show, so really i cant miss it!
Any help would be greatly appreciated
-Nic
Lutz, Fl
My Team Website
The Heavy Chevy Website
  • 72 Cheyenne 10 LWB GM 12-bolt 3.08 w/ Auburn Posi
    91 454 Edel Performer RPM Intake 750 cfm carb Comp Cam 268/.495 Hedman Headers Dual 3'' Exhaust
  • 71 Cheyenne 20 4x4 Fact. A/C PS PB Tilt Currently in the works...
Speak Softly and Carry A Big Block...
There is No replacement for Displacement...
"If everything seems under control, you're just not going fast enough."
- Mario Andretti
HvyChevy454 is offline   Reply With Quote
Old 07-28-2002, 06:39 PM   #2
HvyChevy454
ttt im running short on time so if anybody can help w/ the knowhow it would be greatly appreciated
-Nic
Lutz, Fl
My Team Website
- Mario Andretti
Old 07-28-2002, 10:28 PM   #3
orange72
orange72's Avatar
man i hate to see your question go unanswered so im gonna say something so itll get moved back to the front. then it might get noticed again. later
1972 chevy long bed. Currently under construction!! Bagged, 383/700r4.
orange72 is offline   Reply With Quote
Old 07-28-2002, 10:52 PM   #4
Solver
Solver's Avatar
ttt like to hear a professional answer also
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
Old 07-29-2002, 10:24 AM   #5
HvyChevy454
i really do to!
My g/f got me an Indy Originals Vinyl cover as an early b-day present for the show this weekend. i love her.
really i need to know after wetsanding what kind of compound and what tool should i use to do the buffing?
-Nic
Lutz, Fl
My Team Website
- Mario Andretti
Old 07-29-2002, 11:08 AM   #6
HuggerCST
HuggerCST's Avatar
I'm no pro, but I've done this a few times. What kind of paint? I'm guessing single stage, since you did'nt mention clear. Mix your paint like you were planning to spray it. Sounds like probably a 10 to 5 to 3 mix. (paint to recucer to hardener). You won't need to mix up much, as little as possible. Clean the wax and dirt out of your chipped spots. I use wax and grease remover, but reducer will work too. Take a small paint brush, or fingernail polish brush, and touch up the chips. This is a little trickier if it's a metallic. You may have to put a couple of coats to build it up enough. Let it dry overnight. Take 1500 or 2000 grit paper,(I use 1500) and wet-sand the painted spots with a small sanding block. when it's level enough, buff it out with a foam pad and polishing compound, or by hand. Hand polishing may take a while, but it can be done. That's the way I do it, and it works for me. It also works with clearcoats. If it's not metallic, you usually cant tell where the chip was. There is also a good article on colorsanding and buffing in the paint and body section.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 07-29-2002, 05:56 PM   #7
HvyChevy454
any type of polish works. i tried mequires polish w/ a terry cloth on one of the spots that had allready been wet sanded and i could not get it to shine, you could still see that it was rough. but this was all by hand, to use a machine do you mount a foam pad to an angle grinder? if so who would sell em?
-Nic
Lutz, Fl
My Team Website
- Mario Andretti
Old 07-29-2002, 06:19 PM   #8
gizmo
100% Beefcake
gizmo's Avatar
Form what I know it depends on the paint. I used PPG Concept/Urethane and I mixed it 4 parts paint, 1 part reducer and 2 parts hardener. It also depends on what hardener you use. The information that you are looking for should be marked on the side of the paint can. I hope that this information helps.
1969 C10,350,4:11 posi, Fast Enough
1984 Monte Carlo SS
1987 Chevy S-10, 355 w/150 Shot of Nitrous, Fun,Fun
1938 Nash Lafayette
1956 MG Magnette
gizmo is offline   Reply With Quote
Old 07-31-2002, 03:34 PM   #9
HvyChevy454
im good on the mixing part now and the applying but i need to know how after wetsanding to buff it back to a shine?
-Nic
Lutz, Fl
My Team Website
- Mario Andretti
Old 07-31-2002, 03:44 PM   #10
my new 72
faster, faster, faster
my new 72's Avatar
Do not use an angle grinder to buff with. You will end up burning a j=hole thru the paint. The rpm are way too high. Just go aout and buy a decent buffer from autozone.
I'm going to Law School, wanna debate? It's good practice.
my new 72 is offline   Reply With Quote
Old 07-31-2002, 03:50 PM   #11
HuggerCST
HuggerCST's Avatar
Did you see this article? http://goodspeedmotoring.com/?page=color_sanding
Wynne
Build thread
53 Chevy shortbed
69 Camaro
Old 07-31-2002, 04:58 PM   #12
HvyChevy454
hugger that is exactly what i was looking for
-Nic
Lutz, Fl
My Team Website
- Mario Andretti
