Old 05-08-2006, 06:29 PM   #1
Draggin79
Draggin79's Avatar
To All 73-87's With 1.5" Chopped X-members.
Heya guys, I got some questions for those of you with the 1.5" sectioned crossmembers. I just finally got around to setting my front end up, and i noticed i had some trimming to do on the crossmember around the edges, and on the end of the U-bolts that hold the lower arms on, so the steering could clear. But now i have ran into a bigger problem, when i turn the steering all the way to one side with the truck raised all the way up, the nut on the pittman arm doesnt clear where the bushing on the lower control arm is. And if I were to lower the truck when the steering is turned at max, even just a little, the nut on the pittman arm would bind bigtime with the lower control arm. Just wondering what you guys did as far as clearance of the lower control arm.
Would a set of strong arms solve this?
Draggin79 is offline   Reply With Quote
Old 05-09-2006, 10:34 PM   #2
Draggin79
Draggin79's Avatar
Re: To All 73-87's With 1.5" Chopped X-members.
ttt
Old 05-18-2006, 08:40 PM   #3
Draggin79
Draggin79's Avatar
I know there are a few of you guys out there. What did you guys do to make your pitman and idler arms nuts clear the lower control arm?
If I were to go rack and pinion what setup would you guys suggest?
Old 05-19-2006, 01:10 AM   #4
SCOTI
SCOTI's Avatar
Can you post some pics of the interference?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 05-19-2006, 09:53 PM   #5
Draggin79
Draggin79's Avatar
Ok, I got some pics for you, tell me what you guys think. BTW...the passenger side lower control arm is cut, we are gonna try to make it smaller to clear the nut.
Old 05-20-2006, 12:07 AM   #6
EJC78
No Life Like Low Life
EJC78's Avatar
hey what did you use to paint your frame? (lookin good)
Eric
1978 Chevy Scottsdale
1960 Impala ZZ4
1965 Buick Riviera GS
2011 GMC Sierra Denali
EJC78 is offline   Reply With Quote
Old 05-20-2006, 01:43 AM   #7
SCOTI
SCOTI's Avatar
I'll try & get a lower arm bolted up tomorrow & see if I get the same interference.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-21-2006, 09:34 PM   #8
Draggin79
Draggin79's Avatar
its all painted with POR-15. its just the first coat, im gonna go over and paint it all again i think. the stuff is like paintable powdercoat, it is hard as a rock and doesnt chip off.
Old 05-29-2006, 05:39 PM   #9
SCOTI
SCOTI's Avatar
I PM'd you w/my findings. I only checked the pass side so my guess is it would be the same on the drivers side as well.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
