Old 05-15-2007, 10:03 PM   #1
daveo68
daveo68's Avatar
Dashlight Question
Installed my dash today. I put new dash tach kit with new circuit board,wiring and all that good stuff. Here is my problem,the right turn signal indicator will not light and the fuel and oil pressure gauge lights will not light up. All the other guage lights work. I've swapped bulbs around and they are all good. Could I have a ground problem or maybe bad connection problem with the bulb holders to circuit board?
Thanks,
Dave
68 C-10 Custom LWB
307 V8
Lexington,NC
davideowens@lexcominc.net
God Bless America
daveo68 is offline   Reply With Quote
Old 05-15-2007, 10:09 PM   #2
hiridn69gmc
hiridn69gmc's Avatar
Re: Dashlight Question
It could be just a little pinch in the foil runs where it might be cracked. I would, if you have a multimeter or something to test resistance, check to make sure the foil runs are all intact going to the bulbs. You might not even be able to see the crack in it thats there.
1971 Chevy C-10-sold
1969 GMC 4x4-sold
1997 Chevy Z71
2003 Grand Prix
hiridn69gmc is offline   Reply With Quote
Old 05-15-2007, 10:35 PM   #3
John Fabris
TOTY 2006
John Fabris's Avatar
I had the the same type of problem with my new dash, only I had it on the shelf for about 4 years before I installed it. During that time, one of the foil in the printed circuit was cracked. Ordered a new printed circuit and was much moe careful handling it during install....
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 05-15-2007, 10:40 PM   #4
GREASEMONKEY72
GREASEMONKEY72's Avatar
i 3rd the foil circuit
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 05-15-2007, 10:50 PM   #5
hiridn69gmc
If you have any expirence with a soldering tool and find the crack, if any, you can run a bridge over the foil with another piece of foil if you have the old board or a piece of copper if you have some. You want to keep the same width for continuity, but as a last resort a piece of wire would work too. Make sure to clean the area and cover it with something like epoxy to keep moisture out and it should work fine
1969 GMC 4x4-sold
1997 Chevy Z71
2003 Grand Prix
Old 05-15-2007, 10:54 PM   #6
daveo68
daveo68's Avatar
I'm starting to think this the problem too. Man, I hate taking that dash back out.
Thanks, guys
68 C-10 Custom LWB
307 V8
Lexington,NC
God Bless America
Old 05-16-2007, 06:35 AM   #7
Blazer1970
Blazer1970's Avatar
If the bulb holders are old, I would suspect them first. They will look just fine visually, but will not make contact with the bulb. It is easy to see if you have power up to the point on the circuit board where the bulb holder makes contact.
Blazer1970 is offline   Reply With Quote
Old 05-16-2007, 06:40 AM   #8
byrd
Union Electrician
byrd's Avatar
I would personally check the grounding screws at the top coners of the dash, and if needed put a very thin small washer between the screw and the PCB. You of course will have to take the dash out to do this, but you can also check the PCB while it is out. I personally have never had any trouble with new repop PCB, and I have used several hundered of them, just my .02...Randy
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 05-16-2007, 08:33 AM   #9
RustyParts
RustyParts's Avatar
Also check the little metal tabs on the bottom of the light sockets, they might be corroded and it wouldn't hurt to bend the tabs up a little (towards the foil) so they'll make better contact.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires
The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers!
RustyParts is offline   Reply With Quote
Old 05-16-2007, 10:45 AM   #10
70c10
67-72 Addict!
70c10's Avatar
I would bend the little tabs that hold the bulb inward to make them tight. Make sure they are not corroded. I also bend the ears on the socket to make it tight. Pretty common issue. You could always pull a known good socket out and switch it to the one not lighting to verify.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 05-18-2007, 08:41 AM   #11
daveo68
daveo68's Avatar
Thanks for all the info,I'll try to check things out this weekend.
68 C-10 Custom LWB
307 V8
Lexington,NC
God Bless America
