Old 06-03-2006, 10:15 PM   #1
bpmcgee
bpmcgee's Avatar
engine mount for 283
Hey,
On a truck that originally had a 283 in it, would it have come from the factory with that I6 motor mount rivetted to the front?
Brian
bpmcgee is offline   Reply With Quote
Old 06-05-2006, 09:33 AM   #2
60-66 Nut
Professional Beer Tester
Re: engine mount for 283
Brian, if I recall correctly 60-62 used the horseshoe style front mount on both the I6 and the V8. 63 up used the side motor mounts.
60 Ford F100 Custom Cab
61 Apache Short Fleetside
64 C10 Short Stepside
65 C80 409 V8 5spd(X-Firetruck)
83 GMC 350 Olds Diesel
85 GMC Short Bed
86 GMC Short Bed
90 GMC R3500 Crew Cab
92 GMC 1500
60-66 Nut is offline   Reply With Quote
Old 06-05-2006, 11:19 AM   #3
bpmcgee
bpmcgee's Avatar
60-66,
Yup, you're right. Because of different engine lengths, though, the U shaped mount fasted directly to the cross-member on v8s, and to an extension rivetted to the crossmember for I6's.
My question is -- is this extension deleted for factory v8 engines?
Brian
Old 06-05-2006, 02:30 PM   #4
60-66 Nut
I'm not sure. I know the bracket you're talking about, my 61 has it being a 235 engine. I've only had one 60 that I believe actually came with a V8, and it's been too long ago to remember that. I have seen a few others, but again, I can't recall if they had that bracket or not. I would think the bracket would be deleted if not used, but stranger things have happened. Maybe someone else with a known original V8 truck could help.
85 GMC Short Bed
86 GMC Short Bed
92 GMC 1500
Old 06-25-2006, 09:08 AM   #5
624whldr
drive it not trailer it
is it 4x4 if so the mount is not the house shoe the mount more looks like a newer 2whl dr mount with a lower gusset added back to the frame i just cut a set out and shipped them to CA
624whldr is offline   Reply With Quote
