Old 07-07-2006, 03:58 PM   #1
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Finally Lower-Before and After Pics
I lowered the front end of my truck 2.5" with Western Chassis spindles about a two years ago when I rebuild the front end. I finally dropped the rear with Western Chassis 4" drop leaves a few weeks ago.
I took a "before" picture, but have not had the truck in the same spot since then. I took an "after" pic a couple of nights ago from the other side of the driveway, and reversed it to look like the first one. I wasn't able to match the angle because of the neighbor's lime tree. I'll move things around eventually and take a decent "after" shot.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 07-07-2006, 04:54 PM   #2
see ten
WTB this ad
see ten's Avatar
Re: Finally Lowere-Before and After Pics
Looks good! What size tires are you running with that combo and how do you like the ride so far?
see ten is offline   Reply With Quote
Old 07-07-2006, 06:01 PM   #3
Slonaker
Slonaker's Avatar
I run 255/70/15 BFG Radial TAs for the moment. The tires were purchased before I lowered it. They don't give me any problems, but I might go with a shorter tire in the front next time.
It rode fine with just the drop spindles and new stock coil springs. I don't like the way it rides right now. It is quite bouncy since I lowered the back. Every bump bounces 5 or 6 times before it stops.
I have the cheapest rear shocks I was able to find when I bought them because I was hoping to soften the ride with the stock springs. I never put them on, so I installed them new (sat in the gargage for 4 years in the box) when I lowered it. I also used shock relocaters.
I plan to try some better shocks to see if I can eliminate the bouncing. If that doesn't help, I may try trimming the bump stops, or look into seeing if there are others available to get more suspension travel, though it does not feel like it is bottoming out.
Slonaker
Stock '01 Silverado
Old 07-07-2006, 11:39 PM   #4
SSC's76
No No
SSC's76's Avatar
Re: Finally Lower-Before and After Pics
Looks good!
Thats the same drop I'm going to go with on the 76. Nice to know about the tire size too since it's going to be a while before I get new rubber.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 07-08-2006, 10:07 AM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Looks good
Your probably going to need a much firmer shock because the springs are softer than what you had. Check with Swervin Ervin and see what he's running...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-08-2006, 10:10 AM   #6
boatpuller
boatpuller's Avatar
i like it.
boatpuller is offline   Reply With Quote
Old 07-10-2006, 10:41 AM   #7
Ric83
Ric83's Avatar
Me too. Looks good.
Ric
'83 Silverado SWB Fleetside
Here she is
Ric83 is offline   Reply With Quote
Old 07-10-2006, 02:42 PM   #8
Slonaker
Slonaker's Avatar
Thanks, guys.
Slonaker
Stock '01 Silverado
Old 07-10-2006, 06:19 PM   #9
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
He was running Edelbrock IAS shocks.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 07-10-2006, 06:26 PM   #10
cliffsta
Stepsides RULE
cliffsta's Avatar
Man that's lookin' good. I bought that size tire based on your recommendation and it looks great with that drop, which is the drop I'd go for if I decide to lower mine. So no tire/fender rubs with those 70s I assume?
Lookin' good slonaker', inspired me once again.
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
Old 07-10-2006, 11:07 PM   #11
Slonaker
Slonaker's Avatar
Lookin' good swervin', inspired me once again.
Swervin?
No, nothing rubs anywhere, ever. You have aftermarket wheels, so they may have a little bit different offset.
Slonaker
Stock '01 Silverado
Old 07-10-2006, 11:14 PM   #12
cliffsta
Stepsides RULE
cliffsta's Avatar
Sorry, I was reading about 5 things at once... i fixed it.
Hasn't been my day, needless to say
Old 07-11-2006, 04:45 PM   #13
Slonaker
Slonaker's Avatar
I could do a LOT worse than to be mistaken for Mike. I wish my truck was half as nice as his. His original site, back before he even had a domain name, was the first place I went for information when I was looking for a 73-87.
Slonaker
Stock '01 Silverado
Old 07-12-2006, 11:00 AM   #14
Ric83
Ric83's Avatar
Slonaker
No kidding. I found this place from going to his site. That and finding Dave's site from his stolen truck.
Ric
Here she is
Old 07-12-2006, 04:12 PM   #15
bigarmzz
bigarmzz's Avatar
truck looks killer man!
so whats those drop leaves like?...i've always just seen the shackle flips for the rear i never knew that this was an option
1987 350 TBI lowered 5/7
bigarmzz is offline   Reply With Quote
Old 07-12-2006, 05:32 PM   #16
Slonaker
Slonaker's Avatar
Thanks! The photo I have of it lowered isn't a very good one, but you get the idea.
The drop leaves are like the stock leaves, but they have no overload, and only about 3 leaves. I chose them because I had HD springs on the truck, and I knew they would soften things up.
They come with new rubber bushings, since they are new, and that's a plus. They are also a lot easier to install than shackles/hangers. You don't have to remove any rivets from the frame like with hangers or cut the bed supports like you have to do to clear shackles.
To go really low, I'm guessing a flip kit is probably a better option. I don't plan to go any lower than 4 inches in the back, so these should work out pretty well. The ride is a little soft right now, but I think putting decent shocks on it like was suggested above, will improve that.
It sits dead level right now, but the difference in fender height front to back creates an illusion of the back being lower. I am considering some 1" drop coils to give it just a little rake.
Slonaker
Stock '01 Silverado
Old 07-12-2006, 07:52 PM   #17
Bad Karma
Magnificent bastard
Bad Karma's Avatar
Lookin' good!
How much arch is in the new spring packs with the truck's weight on them (or are they about flat)? How thick are the new springs compared to the old ones? Did they drop your truck exactly 4"?
Thanks!
1977 Big Block Burb
Bad Karma is offline   Reply With Quote
Old 07-12-2006, 08:15 PM   #18
bigblock73
yeller
bigblock73's Avatar
Slonaker, I don't think I have ever seen you post your truck here. I must say, I love your truck, for its simplicity, cleanliness...and timeless good looks that will never go out of style. It looks really sweet lowered just like you have it.
If you ever get bored or have some free time, you should submit your truck to readers rides on 73-87.com...I'd love to add it!
Same goes for the rest of you guys.
bigblock73 is offline   Reply With Quote
Old 07-14-2006, 03:23 PM   #19
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
Thanks!
Slonaker
Looks good, Slon.
I agree. A bit of rake would look even better.
Drop the front ...
Then drop the rear ...
Now drop the front a bit more ...
Opps, Now the rear ...
Ah... just bag it.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 07-14-2006, 04:20 PM   #20
Slonaker
Slonaker's Avatar
Originally Posted by Bad Karma
Lookin' good!
Thanks!
That's a lot of questions! I had to go crawl around the garage and under the truck to get an answer.
The springs have just a slight arch to them.
The old springs were 4 leaves plus an overload. The new ones are just 3 leaves. If you are asking thickness in inches, let me know. I can go measure them.
The drop was very close to 4 inches when I first put them, probably 3.75" or so. I just measured it again, and it is 3" on one side and 3.25" on the other. Part of it is probably due to a little settling. The rest is probably because Costco balanced my tires a few days ago, and they always overinflate them.
Originally Posted by boxrodz
Looks good, Slon.
Drop the front ...
Ah... just bag it.
As much as I would like to install bags, it just isn't in the budget. I have to many other projects, so the money is spread too thin.
I would like to lower it a little more in the front, but I'm afraid that my tires will be too big at 255/70/15. They only have about five thousand miles on them, so I'm not yet ready to replace them.
Thanks! I apreciate the kind words. I know from some past posts that we both like to keep things simple.
I don't have much else planned for the exterior. One of these days I will repaint it, and remove the side trim and badges. I'll probably keep it the same color because I'm too lazy to pull everything apart like you did. I would also like to go with a tailgate handle relocator kit, blazer trim on the tailgate, and a Blazer/Suburban bumper.
Most folks question my taste. I like 15" tires, steel wheels, mirrors that I can actually see things out of, and a real rear bumper. I'll never get rid of the dumbo ears or the Silverado trim. The only added chrome on my truck is the transmission pan, and that is because I wanted one with a drain plug.
I don't usually post photos of it because I have a link to my photo gallery in my signature. I really need to clean it up and take some new photos now that all of the suspension has been updated. Almost everything on my site shows it when it was really tall, with HD springs on the front. When I get some current photos, I'll submit it to your site along with a link to my site (http://www.slonaker.net/truck.html).
Slonaker
Stock '01 Silverado
Old 07-14-2006, 04:47 PM   #21
Bad Karma
Magnificent bastard
Bad Karma's Avatar
Slonaker
Thanks alot, I really appreciate you getting answers for me. Reason I ask about the pack thickness is I was wondering how much drop actually results from the reduced thickness of the pack versus the lesser arch to the springs. I have a Suburban with 8 leaves in each pack, and drop leaves aren't specifically marketed for Subs... So, I basically have to try to extrapolate what springs I need to avoid dropping the Sub too far. (For reference, Performance Online offers several different drops in both 52" and 56" springs.)
I'm with you on the 15" wheels (but I like aluminum), real bumpers and mirrors. Old school is where it's at!
1977 Big Block Burb
Old 07-14-2006, 04:49 PM   #22
TEAM THC
CUSTOM CHEVY FIEND
TEAM THC's Avatar
Lower In The Rear Sure Looks Better.
THE QUEST CONTINUES TO BUILD A TRUCK WITH THE PERFECT BLEND OF OLD AND NEW SCHOOL STYLING.
SEE PROJECT PICTURES AT CARDOMAIN.COM. SEARCH MEMBER ID TEAMTHC
TEAM THC is offline   Reply With Quote
