![]() Join Date: Dec 2013
Repaint without pulling glass
If your considering painting your truck but don't want to pull the glass , You can lift the glass seal and insert a thin cord under the edge of the seal to lift it up enough to mask off that will give you a clean gasket edge against your new paint because nothing looks worse on a fresh paint job as paint on the gasket edge .
I just set this up for pics the truck is getting stripped today. ![]() |
![]() Join Date: Jun 2002
Re: Repaint without pulling glass
Thanks, it's so easy to do but hardly anyone does it right.
Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
great tip-Thanks!
1972 Highlander PAC B 400BB-SOLD 1974 K5 Blazer-6.0 swap 1974 C20 Long Bed 454 1977 GMC HeavyHalf several adopted orphans |
I assume this is motivated by the well-founded fear of removing the windshield, gasket, and trim, and never being able to get them back in correctly? Good tip.
Great tip
Who Changed This?
![]() Join Date: Jan 2013
That's good to know. When I painted the roof of my truck just before I had the new camper shell installed, I cleaned up the surface rust around the windshield (which I had pulled out, because of that rust). I painted the area below the windshield white because I didn't want to also buy orange paint for that small of an area, given what paint costs these days. I'll use your trick if/when I redo the orange parts to make it correct.
A great tip. But on these trucks, after 45-50 years, it's good to know if you have any rust developed before painting and considering it done.
Will you please tell us more about the well founded fear of not being able to get the windshield back in correctly. My truck leaks around the windshield so I already know I have to pull it and fix some rust damage underneath.
back to the top for winter paint jobs ,
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
Great tip. I plan to do that on my '67. Glass is out now and I plan to cut in the openings with the interior paint. The interior will get finish painted but the outside will be painted Hot Rod Flatz Red Oxide when it is first put together. I plan to fully build the truck without dealing with the body work, hence the primered look. It's all good solid used rust-free OEM sheet metal but I want it all one color. I'll deal with the body refinement once it's drivable, or not. I don't want the time or expense of the body/paint to hold things up. If it never gets painted I will enjoy it as a project-look forever.
I use the spline for screen windows. I ended up pulling the glass to paint the roof white
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
![]() Join Date: Jan 2001
It's really just a matter of knowledge that's become pretty rare, especially among younger windshield installers. You need to match the gasket to the trim (there are shallow and deep versions) and put the trim in the gasket BEFORE you attempt to install the windshield. Someone who doesn't know how can fight it for a long time...
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
![]() Join Date: Aug 2014
Amen to that! Best to pull the glass if you really want to preserve your truck. Rust has a way of hiding under the. rubber . But I have used the cord trick for a few quick and dirty touch ups
1972 Chevy Custom Deluxe Highlander, owned 34 years. 1970 GMC Sierra Grande 2500, unrestored, original. 1970 Chevy K10 Short Wide-bed, working on restoration.. 1967 Chevy K10 Short Stepside, unrestored original. 1969 GMC CST (Longhorn) 396, buckets, unrestored. 1995 GMC K2500, 65,000 miles, 454. |
