Old 05-09-2006, 11:24 AM   #1
jrb71c20
jrb71c20's Avatar
Electrical: It shoulda been simple
Replaced the old turn signal swtich yesturday. it worked, just didnt cancel so I thought, what the hell. I did my homework reviewing threads too. How'd it go you ask?... #$% #$%& thang. The only modification I did was remove the little horn button and replace it with a small bolt as a PO did otherwise the horn stayed engaged(S10 type wheel).
Anyhow, I got the new switch in and the colume back together. Easy???...#$% #$%& thang. Neither the turn signal or hazards work and only work (staying solid, no blinking) if I step on the brake? plus, the switch wont cancel. Some of the wires were different colors but, I matched up what was the same and popped em in-in sequential order. Bad switch or did I do something wrong?
jrb71c20 is offline   Reply With Quote
