Old 07-17-2006, 10:30 PM   #1
62 short step
62 short step's Avatar
rockwell 221 transfer case
I need to find out who would have parts for this case, mainly gaskets. If I drop it might as well freshin it up.
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 07-17-2006, 10:32 PM   #2
62 short step
Re: rockwell 221 transfer case
Sorry about the double post.
1965 c-10
86 chevy c/k 20
Old 07-18-2006, 07:30 AM   #3
1969K10
1969K10's Avatar
When I went thru mine, The only gaskets I remember where the PTO covers & the top. I just RTV'd them. All of the seals that I replaced, I just ran to stores to find.
HEre's a exploded view http://www.zianet.com/desertskies/Rockwell%20T-221.pdf
But try drivetrain.com
1969K10 is offline   Reply With Quote
Old 07-18-2006, 07:40 AM   #4
62 short step
How about where the shims are behind the pto cover, did you rtv those as well? Does yours whine while driving also? Thanks for the info! Jeremy
1965 c-10
86 chevy c/k 20
Old 07-18-2006, 02:55 PM   #5
Yukon Jack
Yukon Jack's Avatar
Mine whines when I drive it. I made gaskets for mine. I also replaced all the seals and a local transmission parts house had all the seals when I took in the old ones.
BTW - mine leaks about as much now as before. I didn't put any thread sealant on the various bolts and that probably was a mistake.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 07-18-2006, 03:52 PM   #6
62 short step
Is there anything you can do about the whining? or is that the way they are? Hopefully I'll remember to put sealent on the threads! Thanks for the info.
1965 c-10
86 chevy c/k 20
Old 07-19-2006, 10:15 AM   #7
Yukon Jack
Yukon Jack's Avatar
They whine due to being gear driven. I imagine you could try a synthetic gear oil to see if that quiets it down.
Old 07-19-2006, 12:52 PM   #8
1969K10
1969K10's Avatar
MIne whines, but it's less when I have the correct amount of fluid in it... The stupid little one way valve in the top blows out a lot of my fluid (at least that's where I think it gets out). I keep saying i'm going to get a barbed fitting for it, and run a hose like on my axles...
I didn't have any shims behind the PTO covers... IIRC
Old 07-19-2006, 12:54 PM   #9
62 short step
Thanks for the advice, I might try synthetic or maybe Lucas oil.
1965 c-10
86 chevy c/k 20
Old 07-19-2006, 12:57 PM   #10
62 short step
I guess mine needed the shims for correct clearance or something like that. Wonder if I can rtv a thin layer between each shim? Might try it. Yea that might work out to help stop blowing the oil out.
1965 c-10
86 chevy c/k 20
