Old 07-17-2006, 09:46 AM   #1
myersjeremy
myersjeremy's Avatar
73 corvette motor in '85 truck?
Would there be any issues associated with swapping a 350 from a 'vette into an '85 4X4?
Thanks,
Jeremy
myersjeremy is offline   Reply With Quote
Old 07-17-2006, 10:04 AM   #2
Jonboy
Slots go on anything!
Re: 73 corvette motor in '85 truck?
About the only thing you would need to change are the water pump and all sensors/senders from the truck. Use the truck accessories and sensors/senders, and you will be set. You may need to change the flexplate too, just look and see.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 08-01-2006, 10:48 PM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
74 and older corvette motors have a tachometer driven off the points distributer. The ram horn manifolds are center dump. I believe the rear main oil seal is still two piece until 86. There shouldn't be anything major to overcome. You might want to know that GM started detuning the vette motors in 1973, The L-48 was only rated at 190 horsepower. Mine still runs great however.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
