Old 08-29-2006, 08:42 PM   #1
futura72
power steering box compatability...
I'm looking to upgrade my 72 with power steering. I have been given complete setup from a 77 chev. Will this be an easy bolt in or do i need to look for an earlier model box? Will i need to change the column length to switch over to power steering in any case?
futura72 is offline   Reply With Quote
Old 08-29-2006, 08:50 PM   #2
kwmech
Re: power steering box compatability...
The column length is not really that much of an issue. As far as the box is concerned, it will bolt directly to the frame without any problem. You may want to check and confirm that the lines going to the box are for flared lines and not the 'O' ring style. Even if they are the O ring style, you can match up the pump really easy to get a high pressure line to fit.
Old 08-30-2006, 05:06 PM   #3
futura72
Thanks for the education, I have a lot to learn. I have owned the truck for 16 years and am finally getting around to making it "my" truck.
Old 08-30-2006, 06:46 PM   #4
Huck
Huck's Avatar
Upgrading to a newer one, which will bolt up can also give you a close ratio PS which will make your steering feel more exact. When going newer, you do have to watch for the metric fittings. I forget which year they converted and which year give you the better gears so hang a bit while someone with more experience chimes in!
Huck is offline   Reply With Quote
Old 08-30-2006, 08:45 PM   #5
Southpa
Southpa's Avatar
My experience involved a 70 to 71 front end swap for the disc brakes. The 71I got the front end from was non-power steering and I found that the pitman arm splines ( where it fits onto the box) were different between power and "armstrong" steering. So make sure you grab the pitman off that '77 too, just in case.
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
