Old 09-21-2006, 05:40 PM   #1
gator2511
gator2511's Avatar
Transfer Case Questions
I have a 72 K10 with a 205 transfer case. Got a couple of questions. I was advised to remove the bolts from the frame rail to the side of the transfer case. They said I could break the case if I didn't. What do you guys think? Other question: The rubber cushions on the t.c. side mount are worn out. Probably died of old age! Where do you find them? I don't seem to see them in the run of the mill resto catalogs. I don't mud bog or anything like that. I just drive my truck to work, pull my travel trailer and drive slowly in the woods during hunting season. No real high speed rough stuff. Thanks
gator2511 is offline   Reply With Quote
Old 09-21-2006, 05:54 PM   #2
Blazer1970
Blazer1970's Avatar
Re: Transfer Case Questions
Keep the frame mount, it is there to keep you from breaking the transmission housing. LMC (among others) carries the new cushions for the frame mount.
Blazer1970 is offline   Reply With Quote
Old 09-21-2006, 06:47 PM   #3
gator2511
gator2511's Avatar
Got the parts ordered just now. Never could find them on the other truck part sights I use. Thanks for the advice, I didn't think pulling the bolts would be the right thing to do.
Old 09-21-2006, 07:45 PM   #4
1969 GMC
1969 GMC's Avatar
It seems that after '72, it was hit-or-miss if a NP205 truck got the bracket to the frame. I've heard of a few guys with no bracket breaking the adapter between the transmission and transfer case, and even the bellhousing.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 09-21-2006, 08:03 PM   #5
trkklr77
trkklr77's Avatar
Location: vacaville ca, because it as far from indy as i can be
if you actually wheel it you will wind up like me and restin gthe entire trucks weight on the tcase, keep it. the only situation i can think of was if you like to twist your truck up 90* all frame flex.
trkklr77 is offline   Reply With Quote
Old 09-23-2006, 09:03 AM   #6
Bogus advise from whoever.I`ve never heard of a 205 breaking.He has it backwards.Something can break w/o the brace.
Old 09-23-2006, 02:17 PM   #7
JAKES 68GMC
Aluminum slot wheels rule...
My truck didn't have one on it. Maybe I should make one?
JAKES 68GMC is offline   Reply With Quote
Old 09-23-2006, 05:17 PM   #8
Blazer1970
Blazer1970's Avatar
It is not as much of an issue with a 465 (manual tranny) as it is with an automatic because you have a very stout cast iron bell housing, tranny and t-case adapter - nothing there that will break real easily like a die cast automatic tranny housing.
Old 09-24-2006, 09:12 AM   #9
gator2511
gator2511's Avatar
Thanks for the good acdvice guys. The new parts will be here wednesdayand installed wed. night.
