Old 10-29-2006, 12:58 PM   #1
SSC's76
No No
SSC's76's Avatar
Offset measurment for 3" drop spindles on a 76?
Looks like I will have to get new wheels for the drop but what size wheels will clear for certian with the belltech 3" drop spindles? I would like to keep 15" wheels if possible.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 10-29-2006, 02:08 PM   #2
SCOTI
SCOTI's Avatar
Re: Offset measurment for 3" drop spindles on a 76?
I used 'van' ralleys w/3" BellTech spindles & they didn't rub.
The wheels were 15x6.5" but I'm not 100% on the BS. I can look & see if I have one here to measure but they're prob in my storage unit. I'm guessing about 3.5~4" on the BS.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-29-2006, 03:37 PM   #3
SSC's76
No No
SSC's76's Avatar
If you have that info that would be cool. Seems all the wheels I'm finding localy are 15X7 5-127 -6MM what ever that means. I plan to get started first thing tomorrow on the install and I know now that my 15x8's will not clear and was hoping to get some wheels today if I needed to.
Old 10-29-2006, 08:17 PM   #4
SCOTI
SCOTI's Avatar
I didn't get by the storage unit to measure the van ralleys but I did measure another set of wheels that worked as well.
I had a set of 15x6" vette ralleys built a few years back for my x-wifes S-10 Blazer. These were also used on my 74 w/the same 3" spindles w/o any problems/rubbing. They have 3.5" of BS & if I remember correctly, I used the BS from the van ralleys when ordering these.
Just for those scratching their heads on this one.... I rebuilt the 74's front suspension swapping in the 3" BT spindles @ the same time. I used van ralleys w/stock 5x5 rotors first, then swapped some re-drilled rotors w/a 5x4.75 bolt pattern & used the vette ralleys until I had mt TT2's ready to go.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-31-2006, 02:36 PM   #5
SSC's76
No No
SSC's76's Avatar
Well got it done except for the rear shocks they sent would not fit 2" too short at max extension so I ordered some bilstines which should be in this afternoon. The wheels fit with the minor grinding on the lower control arm and some thin washers for that extra insurance. I still plan on getting some new tires and wheels but it can wait now. Wallmart + impact gun + aluminum wheels = wollowed out holes.
