Old 11-04-2006, 12:39 AM   #1
Deryl
Rear Axle Swap 6 To 5 Lug
I getting ready to convert the 63 to front disc and I will be going from six lug to five so the rear axles have to be changed also. The rear end in it now is a 12 bolt. All of the parts will be coming from a 73 1/2 ton (free doner truck ). I have been told that I have to swap the backing plates in order to use the five lug axles. Is this right and why? If so do I also have to swap drums, brakes etc.? I appreciate any help.
Deryl is offline   Reply With Quote
Old 11-04-2006, 09:47 AM   #2
Demmit_Hemmit's 65
Demmit_Hemmit's 65's Avatar
Re: Rear Axle Swap 6 To 5 Lug
What I did was just change out the whole rear end..............Mine came out of a 71 GMC and was an easy swap................the only difference was the width..........It was just a little wider and not enough to notice..........trade yours for one............JMO........Hemmit
Demmit_Hemmit's 65 is offline   Reply With Quote
Old 11-04-2006, 11:01 AM   #3
Chevy Fleetside
Chevy Fleetside's Avatar
Ditto, but mine was from a 72 is all..
Chevy Fleetside is offline   Reply With Quote
Old 11-04-2006, 12:29 PM   #4
darklord
darklord's Avatar
I’m building one for my wife so I have been asking questions and reading up. The best way seems to be to swap the whole rear end. I am currently tearing down our truck and I will be buying a 72 from a friend soon. Then I will be doing the same swap myself.
darklord is offline   Reply With Quote
Old 11-04-2006, 01:49 PM   #5
Deryl
I really don't want to swap rear ends because the one in mine was rebuilt no more that 1,000 miles ago. New ring and pinion etc. Are the 5 lug drums smaller?
Old 11-04-2006, 08:55 PM   #6
qksilver
The later model axles are longer than your 63 axles. New axles or redrill to the 5 lug pattern and then use the later model rear brakes from the backing plates out
qksilver is offline   Reply With Quote
Old 11-05-2006, 12:17 AM   #7
slepysal
slepysal's Avatar
were can one get a re drill done ?
slepysal is offline   Reply With Quote
Old 11-05-2006, 11:59 AM   #8
raphyel
You should be able to find the five lug axles you need. I have a 63 and I switched the axles to five lug and the backing plates fit just fine on mine. The 72 rear end should accept 5 lug axles with no problem.
raphyel is offline   Reply With Quote
Old 11-05-2006, 12:10 PM   #9
zenish
the 72 rearend IS five lug.71 up axles are 3/4" longer per side.currie at the bottom of the page can redrill your axles.early classics has conversion axles.
1964 c10 short step
1962 econoline van
1989 rs camaro
2006 yamaha vino 125
1975 goldwing
zenish is offline   Reply With Quote
Old 11-06-2006, 02:18 PM   #10
chevy_mike
Never Ending Projects
chevy_mike's Avatar
I had a local shop order me custom axles (K&A Axles) that were in the stock lenght but setup for a 5 on 5 pattern. Then went to NAPA and got '71 drums and put them on. This was on a '68 but the idea should work as I don't think the drums were different on the 6 lugs until the change to 5 lug. About the only thing I could think that could be a problem would be if there was a bigger back drum option, then ??? My .02 worth.
chevy_mike is offline   Reply With Quote
