![]() Join Date: Jan 2005
86 motor in our trucks
Will a motor, 350, out of an 86 Silverado drop into our trucks? What year did carburation stop?
68 Short Stepside C-10 69 SWB C-10 70 Flatbed C-20 70 LWB C-20 BB402 70 LWB C-10 CST 70 LWB C-10 CST 71 Short Stepside Cheyenne C-10 72 LWB C-10 72 Blazer 4x4 4spd 95 Jeep Cherokee 4x4 |
Re: 86 motor in our trucks
86 should be TBI, change the intake and put a carb on it and you should be good to go.
SEMA Network- Protect our Hobby! 71 C30 in pieces, starting to come together. Click here for A Place For Tennessee Truck Enthusiest To Meet |
An 86 truck engine would be carb I believe. I think 87 was the first year for TBI in trucks, but I could be wrong. Should bolt right in, but will have lots of emission crap on it.
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com |
67-72 parts finder
87 was the first year for tbi in trucks, 86 would be a carb engine but i'd make sure it was a 350 first most 86 trucks had the 305 unless it was a 3/4 ton or a ton truck, the 86 350 would have had small valves more than likely, it could have 882s' i imagine which are 76 cc 194, 150 valves and those can be made fairly decent, but if its a driver yes it will work only thing is to be correct you will have to use the short water pump because it will have the long pump hope that helps
![]() ![]() 1981 chevy scottsdale lwb 2wd (parts chaser) 2004 pontiac gto (daily driver) 2004 pontiac grand prix gt (the ol ladys car) 1985 chevy short wide 1970 chevy c10 lwb (another parts rig) 1969 gmc lwb (rainy day project) 1968 chevy lwb c10 250 I6 3 spd (soon to be swb) |
Oilfield Trash
Maniflods probably are a bit different, but if you have headers it shouldn't matter, when i swapped 73 motor in my 85 i had to use the manifolds that came on the 73 engine, can't remember exactly why though.
14 Dodge 3500 Mega Cab 08 Dodge 3500 Mega Cab 87 Chev 3+3 4x4 80 GMC K10 High Sierra bone stock 70 Chevelle 350SS long term project 68 GMC 3ton Grain Truck/Garbage wagon 50 Pontiac 2 Door Coupe Project "I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr. |
I think the reason Blue85 used the early manifolds is because of the dipstick location. I got an early engine in my '86 and doesnt have a dipstick because the manifolds are stock on that truck... I just change the oil alot
Brandon |
laying low
![]() Join Date: Mar 2001
Yes you can use the 86 engine in your truck. I have an 88 engine in my 69. The blocks are the same physically. You need to use the rams horn manifolds or headers. If you get an injected engine you can swap to a carb by swapping the intakes. You may have to mod the 2 center manifold bolt holes on each side of the stock intake as the later models are drilled straight up. No big deal. I have an Edel performer intake on mine with stock quadrajet and headers.
Dave's not here, man
I have a 305 in my 68 that came out of an 86. I just took the 86 manifold off and put my carb/intake from my old 307 on and it worked fine. As mentioned above, I used my factory ram horn manifolds. It was a direct swap.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
Oilfield Trash
Yep, that is what the problem was!
67-72 parts finder
yes some have the dipstick on either side, the 80's were some wierd years for that as well
67-72 parts finder
to whom is using the 88 block if it was the tbi engine i would assume you have a electric fuel pump? i have an 88 engine in my blazer and all the late model engines have what looks like the spot for the manual fuel pump but it is not machined out
laying low
Lilpup. I do have the 88 truck engine in my 69. Originally a tbi engine but now carb'd. The block is bored for a mechanical pump and it came with a blockoff plate bolted to it. Some 88 and 89 blocks still had the mech fuel pump provision. Later on the blocks were cast without the pushrod hole in them. All I had to do was remove the blockoff plate and install the pushrod and pump. It's no big deal to install an electric pump inline if your block isn't bored for the mech one.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross Last edited by Boog; 11-03-2006 at 10:05 PM. |
Firefighter
Mine has a 350 out of an 89 Chevy in it, bolts right in
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA ![]() ![]() |
67-72 parts finder
mine had the blockoff plate bolted on it but when i took it off it wasn't machined for the mechanical pump so i just used in inline electrical pump works fine, maybe this block wasn't an 88 as said it was thats what the guy told me i know at first it had the centerbolt heads on it then i ditched them
