73-87 3" djm lower control arms?
i was just wondering if anyone has has heard, or has had any experience with djm 3" lower control arms? i know it will give you less ground clearance, but what would be any more drawbacks? also how do you think this would work with their 3" spindles.
It'd be alot cooler if you did
Re: 73-87 3" djm lower control arms?
it won't work with 3" spindles at all, the wheels will rub on the control arms. Just use a spring in combination with a 3" spindle. The poly bushings that come in the control arms also squeek like hell if you dont grease the crap out of them.
Even if you grease the crap out of them!
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
the truck is bagged and im running 22" wheels, would that work?
I think it would work the 22s should give you the clearance and with teh large wheel the ground clearance of the lowered pocket shouldent give you a problem butt i have never seen it so i guess you will be the one who has to try it and tell us how it worked out
http://www.cardomain.com/ride/2461088 |
