headers with bags plz!!
I am looking for a set of headers to replace the rusted ones on there now. I am looking at the Hedman Elites, but am wondering if I should get the shorty's since the truck in the future will be bagged.
1970 Chevy C10 "Under Construction" ![]() 2002 Chevy S10 V6 ![]() |
Re: headers with bags plz!!
Depends on how low you expect to go. Some full length headers have plenty of room if you're not laid out. Mine are only about an inch bellow the frame rail, but my frame is about 8" off the ground when dumped, so it's not an issue.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
Well currently the headers are completely below the frame. I am planning to go pretty low. Bags and spindles up front. What kinda headers are u using?
A guy with a truck
You can't go wrong with Hedman Elites. 3/8" flange, 14ga tubing, ball flange collectors, nice coating. If you're bagging it, longtubes will be too low.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
search for headers in title only in suspension forum:
http://67-72chevytrucks.com/vboard/s...earchid=370978 |
Edelbrock shorties let's you use your factory exhaust. So I imagine just about all shorties are the same. They stick out just a little further than the stock exhaust manifol maybe by an inch or so.
Kevin
'93 Silverado Reg. Cab Shortbox .060 over 350 Quick and fun!!! |
soon to be bagged64sub
11108FLT is the part number for the ones that everyone I know uses. They are shortys from Flowtech originally for an older camaro but work great on our trucks.
1969 c-10, bagged, Zd, 20" Boyds SOLD! 1964 Suburban COMING SOON ![]() 1965 c-10 long bed 1993 Sierra x-cab 1999 tahoe-4/5 on 22s 2005 Chevy work truck |
Aight. I found these
Anybody using them?
What?
Here's a list of shortys/blockhuggers:
Flowtech 11108FLT (painted) 31108FLT (ceramic coated) 5/16 flange, 18ga, 1.5” prim. $239.95 Dynomax WLK-86118 (ceramic coated) 5/16 flange, 18ga, 1.5” prim. $285.95 Hedman Elite HED-69640 (painted) HED-69648 (ceramic coated) 3/8 flange, 14ga, 1.5” prim. $294.00 Sanderson CC3 (available in both painted or coated) Info unknown $375.00 Hooker HOK-2466HKR (painted) HOK-2466-1HKR (coated) 5/16 flange, 16ga, 15/8” prim. $369.95 All prices are for coated. What do you think the best deal is? Last edited by jlaird; 02-08-2007 at 08:04 PM. Reason: added info |
Straight jacket required
For Big Block and bagged, I heard Sanderson C5 full length will clear very well.
1968 C10 Short Stepper 350/350 A/C P/S P/B Front disc 3/5 static/ 12bolt rear 3:73 1979 Pontiac Trans Am 10th Anniversary/455/4spd 2011 H-D Street Glide - CAMMED n lowered Dad always said,"Son, if you can't be good...be good at it." ![]() |
Dynomax 3/4 length for chevelle/malibu here ....
A guy with a truck
Chevelle headers were NOT a bolt-in for me. Big time intereference with the motor mounts. Swapping to 73-87 motor mounts cures this problem, but does nothing for the 1/4-3/8" frame 'clearancing' needed. Your results may vary. If I had it to do again, I'd probably spring for the Hedman shorties that fit perfectly with no issues, even considering the screamin' deal I got on the Chevelle style. <--My $.02.
-Chris
#14 | |
Active Member
![]() Join Date: Oct 2006
#15 |
A guy with a truck
Summitracing.com. They are Elites.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 02-09-2007 at 03:35 PM. |
#16 |
Thanks for all the help guys, I think I am going to go with the Hedman coated headers.
#17 |
#18 |
Sorry to hear that gringo ... I know a few people that have used the DynoMax Chevelle\Malibu headers that had no problems.
Were your's DynoMax brand or an another? I ask only because I am curious if there is a difference between manufacturers. |
#19 | |
A guy with a truck
They were the eBay headers. I got them for way less than what they normally go for, so I'm not real upset about doing some small mods to make 'em work. They are surprisingly quality pieces though; thick flanges, heavy tubing, nice coating. I imagine if I'd been using them on a Chevelle, I would have been completely satisfied. -Chris
