Old 10-30-2003, 12:44 AM   #1
miket
miket's Avatar
15x12 backspacing
Just thinking online.....does anyone have any comments on backspacing/offset for pair of 15X12 wheels for the rear of 71 Cheyenne fleetside longbed? I would really like to keep them insode the wheel well. Tires will be 325/50/15s.
FocuzTech Performance
Evergreen Protective Coatings
Gatorhyde...the best kept secret in spray in bed lining & protection
miket is offline   Reply With Quote
Old 10-30-2003, 01:42 AM   #2
low 84
low 84's Avatar
well if you are keeping your axle stock (i.e. not narrowing it) and you want the outside of the 325/50 to be approximatly in the same position of your current tire. then its pretty easy. say you have a 15X8 with 4.5 backspace and you want to go to a 15X12. just add the extra width of the wheel to the backspace, this effectively puts all of that wider rubber inward of where you current tires are now. the 12 ich wheel is 4 inches wider than the 8 so add 4 inches to the backspace. 8.5 backspace on the 12 inch wheel. this wheel would have to be custom made and you would have to look out to make sure its not gonna rub your frame or springs on the inside. i don't think i've ever seen a 15X12 on a non narrowed axle that sits inside the fender. thats alot of wheel. reason i am going with 15X10's with a 325/50 bfg drag radial
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 10-30-2003, 02:41 AM   #3
low 84
low 84's Avatar
i've been doing some research (b/c i'm wanting some custom offset 15x10 truck rallies made for the rear of mine) and i found this chart on stockton wheels website. it shows the backspace they can custom make wheels of a particlular width for. so you could actulay get 12's with 8.5 b.s. and shove all that tire inboard. thats the sleeper look i'd liek to have with mine
'05 1500 Crew Cab
RIP
Old 10-30-2003, 06:36 AM   #4
miket
miket's Avatar
thanks Ryan....I have 15X10's now but thought 12's would be cool.
Old 10-30-2003, 09:03 AM   #5
67sub
67sub's Avatar
A freind of mine has 15x12 welds on his 72, with 7.5 inch backspacing. The suspension is all stock and clears fine but you need to mini tub it or widen the wheelwell about three inches so you don't rub on the inside.
2004 Kawasaki KLR
Always looking for a cheap driver
67sub is offline   Reply With Quote
Old 10-30-2003, 09:15 AM   #6
butter
butter's Avatar
More info anybody I am thinking about doing the same thing.
71 cheyenne 402 th400 swb
71 camper special (PARTS TRUCK)
70 Stepside swb 350
butter is offline   Reply With Quote
Old 10-30-2003, 11:47 AM   #7
miket
miket's Avatar
67:
What size tire was your friend running on his truck?
Can you get any pics?
Old 10-30-2003, 03:07 PM   #8
Adam12
I hate trannys
Adam12's Avatar
I would also like to know the tire size and see some pics of possable.
adam
70 SWB 481 ci, TH-400, Edlebrok Victor Jr. intake, Holley street avenger 770, Dynomax ceramic coated headers. Dual flowmasters. and only 3516134 more little things to do.
Adam12 is offline   Reply With Quote
Old 10-30-2003, 04:33 PM   #9
67sub
67sub's Avatar
miket and adam12 - I'll try to get some info and pics tomorrow night.
2004 Kawasaki KLR
Old 10-30-2003, 04:36 PM   #10
miket
miket's Avatar
Thanks 67 I really appreciate it.
Old 11-09-2003, 02:51 PM   #11
miket
miket's Avatar
67,
Any success on pics?
Old 11-10-2003, 12:32 AM   #12
butter
butter's Avatar
TTT
70 Stepside swb 350
Old 11-11-2003, 12:35 PM   #13
butter
butter's Avatar
TTT
70 Stepside swb 350
Old 01-27-2007, 11:54 PM   #14
Col Clank
Re: 15x12 backspacing
Ttt
Col Clank is offline   Reply With Quote
Old 01-28-2007, 01:32 PM   #15
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Here are 2 shots of my truck
18.5" Mickey's
The bed has been mini tubbed - the frame, shock location etc is all stock.
The wheels are factory rally wheel with a spacer inserted into, just what you folks have been talking about.
I like this since I can always take the truck back to "stock" is I wanted to and for know I get a ton of thumbs up
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
