Old 01-19-2007, 09:16 PM   #1
19GMC63
19GMC63's Avatar
speedo cable problems
I guess not all speedo cables are the same cause the one I bought from LMC don't work.
It fits perfectly in the speedo, but the other end of the cable will not go into the tranny. Its an SM-465 tranny. I know they started using it in '67, so maybe there's something different about the SM-465?
19GMC63 is offline   Reply With Quote
Old 01-19-2007, 09:39 PM   #2
slepysal
slepysal's Avatar
Re: speedo cable problems
I had the same problem. It turned out that the old cable 's tip broke off in the speedo drive gear, I pulled it out and , now it works like a charm.
slepysal is offline   Reply With Quote
Old 01-19-2007, 10:14 PM   #3
19GMC63
19GMC63's Avatar
how did you pull it out?
Old 01-19-2007, 11:52 PM   #4
slepysal
slepysal's Avatar
on my 3 spd there is a retainer held on by I think a 3/8 bolt un do that and wiggle it loose.
Old 01-20-2007, 03:19 PM   #5
19GMC63
19GMC63's Avatar
I don't see any retainer or bolt near the speedo drive gear.
This can't be good.
Old 01-23-2007, 09:10 PM   #6
rodnok1
rodnok1's Avatar
Pretty sure both ends should be thread style, take the old one to NAPA and have them match it up with a new one, the have a listing with pics and end styles/sizes. Just replaced mine last month.
64 Panel Rebuild Pics
Clutch Replacement and Borg Warner T10 Trans Rebuild
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
rodnok1 is offline   Reply With Quote
