This same thing happened to me today with my TH350C, parked on a steep hill. I found this article in the NGs.
Has anyone else had this happen, and if so where can you get some kinda seal for the Yoke?? I'm sure the yoke on my driveshaft is not off the same pickup that my TH350C came off of. Well here is the article, a bit long but.... From: john d. robinson (john@coefac.engr.wisc.edu) Subject: th350 trans leak -- long Newsgroups: rec.autos.tech View: Complete Thread (3 articles) | Original Format Date: 1997/07/14 howdy, I have a 1976 th350. it is a rebuilt unit with 10,000 miles and 10 months on it. about two months ago, I parked it on a very steep hill with the front of the truck pointed up the hill. After 15 minutes or so, I went back to the truck, to find a quantity of trans fluid on the ground underneath the truck. investigation found that there was a small amount of oil sprayed on the undercarriage and cab floor around the end of the trans at the output shaft. Further investigation shows that fluid is leaking from the yoke, not the seal, on the output shaft. I removed the shaft, thinking that I would find a crack in the yoke, to find a 1/16th hole drilled in it at the factory(?). On pondering this hole, I decided that the yoke shaft would need a relief for oil that might get trapped between the trans output shaft, inside the trans, and the yoke output shaft. And so that, when the truck was at an extreme angle, the trans oil collected in the tailshaft, and leaked out this hole. And so, I reassembled the shaft, added fluid, about a pint, and didn't think about it anymore, nor did I lose any more fluid. However, I recently installed a new engine (1963 348 , runs good!) in the truck, and, when removing the engine, discovered that the rear trans mount was torn. When I replaced it, I accidently tipped the transmission so that the output shaft was at an extreme angle , probably causing any fluid to pool at the back end of the trans. I then installed the engine and trans. The next day I noticed a LARGE quantity of trans fluid on the ground. As I was still working on the engine, I figured the same problem happened, and after several days of finishing, the engine ran, and I installed 3 quarts went into the trans upon assembly and running of the new engine. After driving for about 100 miles for the break in trip, (stop and go, and some hiway also) I parked on my slightly sloped driveway. After about 2 hours I noticed a small amount of trans fluid dripping from the tailshaft yoke again. FINALLY, my question is this. What is happening? is my diagnosis of fluid collecting in the tailshaft correct? is the trans failing? Why am I still leaking fluid at the tailshaft? The fluid level is correct. got any imput? Thanks, John Robinson, Mechanician Mechanical Engineering University of Wisconsin 1513 University Ave. Madison, Wi. 53706 608-262-3606 FAX 608-265-2316 Current World Land Speed Record Holder Bonneville Salt Flats H/GCC 92 cu.in. 1980 Dodge Colt 131.333 MPH set 1995 136.666 MPH set 1996 -------------------------------------------------------------------------------- ------------------ Rod Childers '71 C10 Stepside
Rod Childers '71 C10 Stepside |
