Old 01-26-2007, 12:52 PM   #1
Livrat
Member #1049
Livrat's Avatar
4 inch lift front spring differences??
I have a set of 4 inch lift Rancho front springs in my 68 3/4 4X4 and to put it bluntly the ride sucks..
I also have a set of Rough Country 4 inch springs..
Does anyone have personal experince between the two as far as the ride goes??
I figured I would ask before I spent the time to switch them just to see if the ride will improve a bit...
Livrat is offline   Reply With Quote
Old 01-26-2007, 05:47 PM   #2
Zoomad75
K5Camper
Zoomad75's Avatar
Re: 4 inch lift front spring differences??
Generally, The Rough country springs have more spring rate than the Ranchos. Not by much but, both are still stiff compared to something like a tuff country or BDS spring.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 01-26-2007, 05:52 PM   #3
Blazer1970
Blazer1970's Avatar
agreed
Blazer1970 is offline   Reply With Quote
Old 01-27-2007, 01:29 PM   #4
Livrat
Member #1049
Livrat's Avatar
Cool, Thanks for the replys... Just saved me the time of swapping just to see..
Old 01-27-2007, 04:03 PM   #5
Americanrider
What shocks are you running? I put on a set of Rancho RSX 9-way adjustables. Run them all the way down to setting number 1 and they are real soft/flexy.
Americanrider is offline   Reply With Quote
Old 01-27-2007, 06:08 PM   #6
ND_guy
Tool Addiction=Money Shortage
ND_guy's Avatar
I have the Rancho 4inch springs also and the ride is poor. I could've just saved money and installed add a leafs. The ride couldnt be much worse.
ND_guy is offline   Reply With Quote
Old 01-27-2007, 11:07 PM   #7
Livrat
Member #1049
Livrat's Avatar
I am running Rancho RS5000's.. Hmmmmm.. maybe a different set of shocks is in order??
Old 01-29-2007, 09:05 AM   #8
Ive used Heckothorne`s(Superlift)hydraulic shocks for a much better ride.Nitrogen shocks are intended to fight airation in off road raceing with alot of friction build-up from constant coil/recoil.I don`t drive like that,so the "oil" shocks worked fine.I have the 9000RSXs on my`91 diesel`Burb set in the middle with EZ-Rides(TuffCountry)because it`s a heavy truck(tools in back).When empty,the softest setting is good,but I see more roll.Set on hardest setting is a tight ride.It rode pretty good with two sets of 1t axles in the cargo area,though.
