Old 02-17-2007, 10:30 PM   #1
tractor8694
Unhappy i need help
i have a 1973 gmc 2500 and i have had to replace the transmission in it. i cannot get the speedometer to register the right speed. cananyone give advice? thank you
tractor8694 is offline   Reply With Quote
Old 02-17-2007, 10:52 PM   #2
Mudder
Mudder's Avatar
Re: i need help
moving this over to a place where you might get more help.
Mudder is offline   Reply With Quote
Old 02-17-2007, 10:53 PM   #3
larry may
Re: i need help
Speedo gear, Make sure you have the one from the original trani. Also see if the speedo cable is not in a bind. or partially melted against the exhaust. Good Luck..........
The biggest problem people have, is other people
Thou shalt be cool and not hassle
Be a site supporter.
The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2
larry may is offline   Reply With Quote
Old 02-17-2007, 11:40 PM   #4
Russell
Professional Grade
Russell's Avatar
Re: i need help
Yep, need to change your speedometer gears...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
